Old 03-21-2017, 09:13 PM   #1
KEN2939
Default Rt front hub not coming off
any suggestions, rt front hub wont come off, soaked with PB blaster, adjusted and backed off brake adjustment, still wont come off????
KEN2939 is offline   Reply With Quote
Old 03-21-2017, 09:30 PM   #2
Bob C
Default Re: Rt front hub not coming off
Is the outer bearing stuck on the spindle??
Bob
Bob C is online now   Reply With Quote
Old 03-21-2017, 09:36 PM   #3
Marshall V. Daut
Put the wheel and tire back on with lug nuts so that you have more leverage to wiggle the brake drum/hub free. With the outer nut removed, spin the wheel as fast as you can and have someone hit the brake pedal. That might jar the drum loose.
If you backed off the adjusting wedge and the front drum still won't come off, try prying the large retainer washer and outer bearing out of the hub. The bearing may be galled to the spindle for some reason. It doesn't "thread" on, like a Model T. It should just slide off once the outer keyed washer is removed. If you get the washer and outer bearing out and the drum STILL won't come off, that can only mean that one (or both) brake shoe is still too tight or somehow hanging up against the drum.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 03-21-2017, 09:37 PM   #4
Marshall V. Daut
Rats! I was typing when "Bob C" posted similar advice. 'Sorry for the duplication of advice.
M.
Old 03-21-2017, 09:46 PM   #5
KEN2939
will go at it again tomorrow night, thanks for all the help!
Old 03-22-2017, 06:41 AM   #6
1crosscut
1crosscut's Avatar
If your drum moves out a little ways and then stops you may have a ridge of heavy crud built up on the outside edge of the drum that the shoe is hitting. If so take a torch and run the flame around and around and around the outside edge of the drum to soften the ridge enough to pull the brake drum through it. It may take a while.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-22-2017, 10:46 AM   #7
Fullraceflathead
Fullraceflathead's Avatar
There is a very slight change the inner bearing race spun and welded itself to the spindle.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 03-22-2017, 12:42 PM   #8
Mitch//pa
Does the drum rotate after unadjusting the brakes? If not your shoes are rusted to the drums..
