How does one get a 6v crab style distributor for a '46 flathead?
He sends his old one to Bubba and gets it back with different cap and clips and all dialed in. Worked very well for me. If your distributor is already real good, then you just get a crab cap and rotor and different clips, but I'd send it to Bubba. It's what he does. My .02.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
look here..
http://www.bubbasignition.com/crab-42-48.html and http://www.bubbasignition.com/orders--.html no core needed at this time...... ![]() |
Hello Gear Rat
I just went through this, well ,just about through it, am assembling my distributer this week end, based on what I've learned here on the Barn Bubbas the only way to go, see my posting on here, " '46 Crab distributor/wire assy " lots of comments there, I tried using a plug wire set from Bob Drake, was the one he lists for '46, its plastic coated and WILL NOT fit inside the 2 piece cap, that's $45. US down the drain. Am going to use Packard Delco wire, am sure it will work PM me if we can share info |
Bubba can get you the right parts and set you up with a "sweet" distributor. And Jim (Bubba) is always ready to help you along the way. A great resource.
We have the adapters.
http://www.vanpeltsales.com/FH_web/i...prices-pg1.htm It's the IS-3241 adapter.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
Hey guys!
Looking to go with a Mallory 12v distributor, but have a question... Will we need to change the stock crank pulley to accommodate for it? |
Talk to Bubba!
oldasi
Be gald to help anyway i can... However the orginal post wanted to know how to get a six volt crab distributor.?? Then you wanted a adapter tp put a crab on a early helmet cover....?? Then you wanted to know if the Mallory distributor would clear the front pulley.?? I guess the answer is "sure" ?? ![]() ![]() BTW not beating on you but this is so much my everyday world..... ![]() |
We've settled on upgrading to 12v so we want to pursue the Mallory option
Mallory is OK, I have one bought cheap on ebay and also a pertronix. You can put a pertronix unit in a stock distributor for less money. 6V or 12V.
41 woodie https://41fordwoodie.weebly.com/ |
#13 |
Bubba
Saw your comments, not sure I made these comments ..... However the orginal post wanted to know how to get a six volt crab distributor.?? Then you wanted a adapter tp put a crab on a early helmet cover....?? Then you wanted to know if the Mallory distributor would clear the front pulley.??[/U] I think you may have me mixed up with someone else's comments, hope this clears things up |
#14 | |
![]() Quote:
#15 |
I've dealt with both Bubba and Charlie NY. Both top notch. Bubba made-up a few Pentronix crabs for me and Charlie made a crab with points for me. All 12 volt and furnished with coils.
#16 |
Is this adapter supposed to be here? What do I do now? Lol
#17 |
To keep the water from getting more muddy. If you have a three bolt dist, there is a good chance you have a 221 cu in engine, not a 59AB 100 hrs 239 cu in. If you have a three bolt timing gear cover and want to run a crab type 42 dist., you will need an adapter.
#18 |
As you can see, the slot of the adapter is not as wide as the slot of the cam. The adapter we have here is at least from the '40s. So, question is... Do we try reusing this adapter or go with a new one that spans the slot of the cam?
