Old 02-08-2017, 07:52 PM   #1
Tjfoster
Default Question
Looking at my dad's original 1930 sedan been setting for a few years and the spark advance and throttle levers on the column are lock23rd up is there any way to free them up?
Tjfoster is offline   Reply With Quote
Old 02-08-2017, 08:06 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Question
Firstly, I'd make sure it is the levers that are stuck. Try taking the rods off the bottom and trying again. The top plate in the distributor might be stuck - same with the linkage at the back of the block for the hand throttle. Does the accelerator pedal move OK? If all this still indicates they are stuck, try a little penetrating fluid on them top and bottom. They might be stuck at either end. If the bottom ends is where the problem lies, try some heat on the column where the rods exit and a tap with a hammer. let us know how you go.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 02-08-2017, 08:15 PM   #3
Jacksonlll
Jacksonlll's Avatar
I just freed up a spark lever. After all the solvents etc, I had to twist off the shear pin on the bottom and pull the rod out. Clean it up and reinstall it. They are strong. I don't think you will break it.
Old 02-09-2017, 12:43 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Do NOT use WD-40, as that's bad on the top potmetal bushing. My 28 were froze from non use when I bought the car. I sprayed some Gibbs or Kroil on the top bushing and lower end, then pulled down hard on them. They moved, so I put oil on them and forced them up and down several times. They were still tight, but keep getting better with use, so I'm good to go. Keep oil on all moving parts, and don't forget the 2 oil pockets on top of the throttle linkage, and the distributor oil cup.
Old 02-09-2017, 09:00 AM   #5
SeaSlugs
SeaSlugs's Avatar
Yea pot metal swells up with age - mine were so stuck kroil and a hammer had to tap them out while someone pulled up...(pot metal was cracked and looked like a poofed up marshmallow...)
I really hate pot metal....
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-09-2017, 09:23 AM   #6
Ray in La Mesa
A better rust penetrant than even Kroil is a 50/50 mix of acetone and ATF,shake well, apply and let soak. A study was done to show torque needed to remove rusted nuts:
No oil……………..516 FT/LBS
WD40……………..238 "
PB Blaster……….214 "
Liquid Wrench…127 "
Kroil…………………53 "
It works!
Ray in La Mesa is offline   Reply With Quote
Old 02-09-2017, 10:59 AM   #7
Dick Steinkamp
Dick Steinkamp's Avatar
Here's a study from Machinist Workshop...
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster .............. 214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............. 106 pounds
ATF-Acetone mix....53 pounds
http://www.practicalmachinist.com/vb...ng-oil-196347/
Oddly similar to the above.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 02-09-2017, 11:01 AM   #8
redmodelt
redmodelt's Avatar
WB40 is a water displacement (WD) lube (the 40th try to get it right) not penetrating oil.
Old 02-09-2017, 11:21 AM   #9
Cornishman
Cornishman's Avatar
The WD40 sold in Europe must be a different product.
Cornishman is offline   Reply With Quote
Old 02-09-2017, 05:52 PM   #10
Synchro909
Synchro909's Avatar
I doubt it but...
WD40 is as has been said, a water displacer. The main ingredient is fish oil, in fact, there is nothing in WD40 that is unsafe to ingest, I have heard.
Old 02-09-2017, 07:13 PM   #11
Marvin/TN
Send a message via AIM to Marvin/TN
There is a penetrating oil made by WB 40, not the regular WD 40.
Marvin/TN is offline   Reply With Quote
Old 02-09-2017, 07:45 PM   #12
Chuck Dempsey
Chuck Dempsey's Avatar
What exactly is 'pot metal'? An alloy of some sort, I imagine. But with what purpose was it used? Was it the 'aluminum' of it's day? Thanks
Chuck Dempsey is online now   Reply With Quote
Old 02-09-2017, 07:52 PM   #13
Mitch//pa
https://en.m.wikipedia.org/wiki/Pot_metal
Old 02-09-2017, 11:30 PM   #14
Drive Shaft Dave
A welder friend of mine told me what the alloy was but i cant remember the second element, the first was zinc. Pot metal is very cheap metal.
Drive Shaft Dave is offline   Reply With Quote
Old 02-10-2017, 08:21 AM   #15
Chuck Dempsey
Per the wiki article mentioned by Mitch//pa (thanks) -
Pot metal—also known as monkey metal, white metal, or die-cast zinc—is a colloquial term that refers to alloys of low-melting point metals that manufacturers use to make fast, inexpensive castings. The term "pot metal" came about due to the practice at automobile factories in the early 20th century of gathering up non-ferrous metal scraps from the manufacturing processes and melting them in one pot to form into cast products. A small amount of iron usually made it into the castings, but too much iron raised the melting point, so it was minimized.
There is no metallurgical standard for pot metal. Common metals in pot metal include zinc, lead, copper, tin, magnesium, aluminium, iron, and toxic cadmium. The primary advantage of pot metal is that it is quick and easy to cast. Because of its low melting temperature, it requires no sophisticated foundry equipment or specialized molds. Manufacturers sometimes use it to experiment with molds and ideas (e.g., prototypes) before casting final products in a higher quality alloy.
Sounds like 'stew' for cars....
