Old 01-06-2017, 09:04 AM   #1
Terry, NJ
Terry, NJ's Avatar
Default Acetone in gas
I just saw something on the I-net I haven't seen before. I know, The myth busters did a show on it eight years an I missed it, or something! Acetone in gas! Using the rate of two ozs per ten gals they supposedly raised gas mileage from mid 20s to thirty MPG. But it only works for the first day, after the first day, it is longer effective. Is this of any real benefit? This sounds like one of those obscure "Fixes" that have been around for a long time, but I somehow missed it.
Terry
Old 01-06-2017, 09:22 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Acetone in gas
I remember the first time I heard of this about 10 years ago, so I bought some acetone and tried it. My gas mileage had NO change.
Old 01-06-2017, 09:51 AM   #3
C26Pinelake
A wives tale at best! You missed nothing! Wayne
C26Pinelake is offline   Reply With Quote
Old 01-06-2017, 10:16 AM   #4
holdover
Don't know about it increasing mileage, but for all you Seafoam users might want to consider a home brew. I have been doing this for years. At 1/10 the price it is the way to go, at least to me, your mileage may vary.
http://www.clubxterra.org/forums/arc...p/t-21417.html
holdover is offline   Reply With Quote
Old 01-06-2017, 11:06 AM   #5
Ruth
Think about it. That's something like 640:1 ratio. I don't think it would have much effect.
Old 01-06-2017, 11:13 AM   #6
SeaSlugs
SeaSlugs's Avatar
not to mention acetone evaporates in seconds, not sure if its heavier or lighter than gas so if its lighter it would just evaporate away. It would clean out the junk from an engine so i wonder if they saw better mpg from a clean vs dirty engine...
also what vehicle was it in? a pickup truck will not see an improvement due to it being about as aerodynamic as a tool shed. Something like 75% of your MPG depends on your foot and aerodynamics of the vehicle.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-06-2017, 11:36 AM   #7
Fullraceflathead
Fullraceflathead's Avatar
Actually Tolulene is the one to add to improve octane. They Oil companies are adding it to Regular to make premium
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is online now   Reply With Quote
Old 01-06-2017, 02:01 PM   #8
stouchton
stouchton's Avatar
Dude, thanks for that! Just about spit my coffee on the keyboard!
stouchton is offline   Reply With Quote
Old 01-06-2017, 02:38 PM   #9
Dick Steinkamp
Dick Steinkamp's Avatar
http://www.snopes.com/autos/techno/acetone.asp
https://www.quora.com/Gas-Mileage-Wh...oline-in-a-car
http://www.popularmechanics.com/cars...hall-of-shame/
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 01-06-2017, 02:48 PM   #10
captndan
captndan's Avatar
The first thing that comes to mind using acetone is those squeaky clean pistons.
captndan is offline   Reply With Quote
Old 01-06-2017, 06:39 PM   #11
Terry, NJ
Terry, NJ's Avatar
Thanks Guys! I thought it was crap! When you hear this stuff you wonder "He can't be the first!" After 100 years of trying everthing from Goose grease to cow magnets we pretty much know what works and what doesn't.
Terry
Old 01-06-2017, 06:50 PM   #12
C26Pinelake
Now where did you ever hear that? My brother is a chemist at a major oil company and he said that was his laugh for the day, month and year! Wayne
Old 01-06-2017, 07:09 PM   #13
Tom Wesenberg
I like the third link the best. I remember in the late 60's seeing several cars with magnets taped to the fuel line. I think this only helped while the car was pointing north though.
Old 01-06-2017, 07:13 PM   #14
larry harding
following this thread reminded me of hearing my dad talk about w w 11 when he was in the navy. gas was rationed and he would run a mixture of kerosene and moth balls just to get around. the kerosene is not too far fetched as a lot of early tractors and flywheel engines were designed torun on kerosene once they were hot. kero was cheaper than gas.
larry harding is offline   Reply With Quote
Old 01-06-2017, 08:40 PM   #15
ursus
Acetone works well for getting water out of gas. I use it in my lawn mover after it has been stored over the winter as it helps to dissolve any gunk that might develop with storage even after adding Stabil when putting it away for winter.
Old 01-06-2017, 09:55 PM   #16
40 Deluxe
I was always told that 'squeaky' pistons were a sign that the engine was out of oil!
Old 01-08-2017, 12:38 AM   #17
ian Simpson
Up here in the cold, condensation (water) in the gas tank is a real problem as it can freeze in the gas line. It used to be that in cold weather we would put a few ounces of methyl hydrate in the tank at each fill. Ethanol in the gas seems to have cured the problem. Hooray for crap gas!
ian Simpson is offline   Reply With Quote
Old 01-08-2017, 01:02 AM   #18
Dodge
I heard that if you put gas in the gas tank it worked pretty well. Google it.
Dodge is offline   Reply With Quote
