Old 01-05-2017, 01:35 PM   #1
bwaii64
Default Don"t touch that bolt
I was searching for timing procedures for the oil pump gear to get the slot in the right place so distributor would line up. THEN I realized it doesn't matter where the slot is because the distributor cam is loose and you can put it where ever you need. (where's the smiley face with a palm smacking the forehead???)
BUT
In the process, I read you should not touch the bolt that I thought held the oil pump in place. Is that bolt with a jam nut in the block near the oil pump not to hold the pump in place?
https://www.fordbarn.com/forum/showth...+oil+pump+slot
SaveSave
bwaii64 is offline   Reply With Quote
Old 01-05-2017, 01:58 PM   #2
Vin-tin
Vin-tin's Avatar
Default Re: Don"t touch that bolt
BUT
SaveSave
If the bolt with jam nut you're referring to is on the "head", that one holds your distributer in. The other bolt down near the oil pan should just be a "plug" to close the hole up. The oil pan actually is what holds the oil pump up into the block. There is a special bolt people use in that lower hole to that replaces that plug. It holds the oil pump in place while dropping the oil pan. Remove and plug when pan is re-installed. Others will probably chime in.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 01-05-2017, 02:02 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
On the top of the block there is a bolt with a jam nut that holds the distributor in place.
Further down near the oil pan is a pipe plug with no jam nut.
Old 01-05-2017, 02:21 PM   #4
Brian T
Brian T's Avatar
SaveSave
[/QUOTE]
If there is a bolt in the block just above the pan rail, before you remove the bolt you should make sure that the spring isn't missing that holds the pump, if its missing the pump will fall down causing severe damage.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 01-05-2017, 03:06 PM   #5
J Franklin
J Franklin's Avatar
The spring needs to be on the bottom of the pump, and the pump needs to float on that spring because the assembly as Ford engineered it acted as the pressure relief. Don't use a bolt where the oil plug is.
Old 01-05-2017, 04:12 PM   #6
SeaSlugs
SeaSlugs's Avatar
ohhh i wondered why it had that setup...learn something everyday!
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-05-2017, 05:15 PM   #7
700rpm
700rpm's Avatar
Mike used the correct term. It is a plug, and it has a pipe thread. Replacing it with or using a bolt or screw can damage the threads in the block, but "touching it" (whatever that means) doesn't hurt anything.
I've never had a pump fall down; if it's loose it just drops with the pan, and Unless you've got it on a lift, and it should happen to momentarily stick when the pan is dropped, I don't see how severe damage could occur, and even that seems unlikely.
Ray Horton, Portland, OR
Old 01-05-2017, 06:35 PM   #8
Brian T
Brian T's Avatar
Ray,
There was a change to the way the pump spring was retained --- SB Feb 30 , the reason was Ford were concerned that if an oil pan was replaced and the spring which originally was clipped to the oil pan (not the pump) and forgotten, the lock bolt once removed, the pump falls down resulting no oil pressure or worse tangled up in the crankshaft.
Only the plug as a pipe thread, a fine thread bolt can be used snugged up lightly.
Old 01-05-2017, 07:29 PM   #9
Dick Steinkamp
Dick Steinkamp's Avatar
I'm scratching my head on this one. Can you explain further?
I can't see of a way the pump would go over pressure and need relief. It basically pumps oil under very low pressure to the valve chamber. From there, the oil flows out the "window" on to the timing gears and/or out the oil drain back pipe back to the pan. There is no restriction that I can see that would build pressure. Under what circumstances is too much pressure obtained?
If it does for some reason go over pressure and the pump drops and depresses the spring, where does the oil then go? If it drops down too far, won't it become disconnected from the drive pawl for an instant, then try to reengage with much clatter and busting of parts?
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 01-05-2017, 07:57 PM   #10
Benson
Someone sells a threaded fitting that screws into the lower hole which has an internal thread and bolt for the purpose of retaining the oil pump ONLY when removing / installing the oil pan.
If you choose to use this device DO NOT tighten the bolt too much ... the engine casting is thin in this area and might break if too tight.
Old Fart Society: charter member,
Old 01-05-2017, 08:06 PM   #11
DaWizard
Send a message via AIM to DaWizard
Originally Posted by Benson View Post
Someone sells a threaded fitting that screws into the lower hole which has an internal thread and bolt for the purpose of retaining the oil pump when removing / installing the oil pan.
Thanks, I was going to ask if I could make my own just like that since I have a brass plug and who knows what kind of screws layin around to do it with.
Da Machinist Wizard
DaWizard is offline   Reply With Quote
Old 01-05-2017, 08:16 PM   #12
700rpm
700rpm's Avatar
Originally Posted by Brian T View Post
Ray,
Brian, I am familiar with that service bulletin, but it says nothing about a locking bolt. As Vince noted, Ford never used a locking bolt for the oil pump on an A.
Old 01-05-2017, 10:02 PM   #13
J Franklin
J Franklin's Avatar
Thirty wt oil in the early morning is quite viscous The pump tries to pump lots of oil and sometimes needs a relief. the oil spills back into the pan. This is why most oil pumps incorporate a spring loaded relief valve. Something would have to already be seriously wrong to press hard enough to uncouple the pump.
When I place the pump I use a piece of paper to shim the pump to block and it holds the pump up while replacing the pan.
Old 01-05-2017, 10:06 PM   #14
Brian T
Brian T's Avatar
Your correct, NOBODY on this thread including myself said that FORD used a locking bolt to hold the pump in place, the original poster stated there was a bolt he believes was holding the oil pump in place, I had the same thing when I got my truck, and was advised by someone on this board not to remove it until I was sure the pump retainer spring was in place, if the spring is missing the pump falls down and can cause severe damage, yes and can hit the crankshaft.
Some on this Forum have opinions that are outright there way and no other, and are rude to boot, absolutely no reflection on you Ray, Happy New Year.
Old 01-05-2017, 10:11 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
And be sure to check the oil pump spring for any signs of rust or pits. Replace it if any pits or rust is found.
Old 01-05-2017, 10:14 PM   #16
Dick Steinkamp
It looks to me like the oil is pumped to the rectangular slot near the top of the shaft then travels up to the valve chamber via the groove in the shaft. The pump would still have to pump oil the same distance dropped or not dropped. I don't see how this would be a "relief" for the pump. If it does drop, how does the oil travel back to the pan? It doesn't look like there is a path to do so.
I'm sure there is an explanation, I just can't see it yet.
Old 01-05-2017, 10:29 PM   #17
Tom Wesenberg
What the............... Is that a Philips screw I see holding the cover in place?
Old 01-05-2017, 10:54 PM   #18
Joat1000
Joat1000's Avatar
Ray,
I wondered why mine had the spring in the pan, something else that I learned on the Barn that I hadn't seen anywhere else.
Joat1000 is offline   Reply With Quote
Old 01-06-2017, 12:49 AM   #19
700rpm
700rpm's Avatar
It seems I have very little to contribute here. Sometimes the written word in a forum is not the best or clearest way to communicate. I need to step away for a while.
Old 01-06-2017, 05:01 AM   #20
bwaii64
Wow. You guys really get into it. what a passionate group!
Yes the plug has been replaced with a regular bolt and nut - though I didn't realize it had been a plug. It was holding the pump in place. 1) the mechanic that dismounted it said so and 2) there are bolt bite marks on the flat that looks like it was made to hold the pump in place.
it will be backed off or replaced when re-installed.
