Old 01-04-2017, 01:01 PM   #1
Del in NE Ohio
Del in NE Ohio's Avatar
Default Mitchell O/D with cable operation
I agreed to help a club member install his Mitchell O/D when he receives it. He has ordered the cable option to replace the operating lever. I've never seen the cable setup. Any 'Barners have experience with this setup? Photos?Tnx!
Del in NE Ohio is offline   Reply With Quote
Old 01-04-2017, 02:10 PM   #2
duke36
Default Re: Mitchell O/D with cable operation
Yes, have Mitchell cable in another later mid '30's car. The cable extends down from bracket under dash and is curved over to steering column opening before it runs thru firewall and under car. The trick is to make sure cable is proper length for adjustments (to be able to push/pull cable for proper engagement and with gradual curves over its length).
Old 01-04-2017, 02:43 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
And be sure to keep the cable well lubed. I like to remove the inner cable and squirt oil down the housing, then push the cable in while running it through some grease in my hand. This is the same way I do speedometer and any other cables. I need to tighten the cable a bit on my snowblower now because after I oiled it, it won't stay on high speed.
Old 01-04-2017, 03:16 PM   #4
Synchro909
Synchro909's Avatar
I have a Mitchell O/D in 3 Model As, all operated by the standard extra lever behind the original shift. I don't like the extra lever. When I enquired at Mitchell about converting to cable, they gave me a price which I can't remember now but I'd have to sell the house to buy one.
Now the Hijack! Does anybody have any other ideas on how to get rid of the extra lever short of taking the O/D out of the car (won't happen). Solenoid perhaps?
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-04-2017, 03:56 PM   #5
Lawrie
Lawrie's Avatar
Arnold, look at the two speed eaton axle shift motor of an old bedford,or a throttle shift motor of a JLG boom lift.
Lawrie
Old 01-04-2017, 04:19 PM   #6
Synchro909
Synchro909's Avatar
Lawrie
Thanks Lawrie, I'll do some sniffing around.
Old 01-04-2017, 04:58 PM   #7
2manycars
2manycars's Avatar
I was thinking a 6 volt linear motor with proper linkage would work.
A google search showed several suppliers.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 01-04-2017, 05:00 PM   #8
MAG
MAG's Avatar
This one has been installed about 3 years. Daily driver. No trouble.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 01-04-2017, 05:31 PM   #9
Tom Wesenberg
That sounds like it would be a good choice.
My neighbor just bought a low hours John Deere lawn tractor, then went to another dealer and bought a snowblower attachment. Now he wants to buy the cable that tilts the end of the chute, but John Deere wants $300 for the cable and 2 simple brackets to hold it.
Old 01-04-2017, 06:19 PM   #10
Synchro909
Synchro909's Avatar
That's the sort of thing I found when I enquired at Mitchell about converting to cable. I bet they don't charge much if any more for a cable change new!
My only reservation about a linear motor is that they apply a fairly large force which might put too much pressure on the synchro rings for longevity, especially when it is still cold. I'd lose the ability to "feel' the change. Only need a "throw" of about 3/4". Most seem to be waaay more than that. Might need to put a cut out switch on it to limit the travel. Not a bad thing anyway.
Old 01-04-2017, 06:30 PM   #11
Tom Wesenberg
I have the same concern about not being able to feel the shift.
I took some GM power window units apart after the cables broke, and the motors have a set of tension contacts that limit the travel when the glass reached a certain level of resistance. Say you are raising the glass and it reached the top, then the UP contacts open, so it won't keep trying to go up even if you push the switch up. The same holds true for lowering the glass.
Now, maybe out frozen wipers to glass need the same limit switch.
Old 01-04-2017, 07:09 PM   #12
Synchro909
Synchro909's Avatar
Car makers would have to do that to cover idiots who might have their head out the window while someone winds it up. With no tension switch, that could be fatal.
Never seen a wiper frozen to the window here.
Old 01-05-2017, 08:03 AM   #13
Del in NE Ohio
Tnx Mag! Just the input I needed! I talked to my friend Tom Jordan at Snyders yesterday and he told me that he had sold several of the cable operated unit, mostly to Aussies with RHD cars. No reported problems.
