Old 12-03-2016, 02:24 PM   #1
Alaska Mike
Default Barn Find Help Me Identify
Local widow called asked if I knew anyone who would be interested in her late husband's extra engine and transmission for a Model A. She knows nothing about it. It has been stored in her brother's barn for at least 15 years. Good dry location. Transmission shifts very good and seems very tight. Pulled a spark plug out and no rust visible when I looked inside. No starter, distributor, or carburetor. Could not get it to turn over by prying on the ring gear, but I really didn't have a proper wrench or bar.
It looks to have been set up for a stationary application, as it has a very unique exhaust manifold and intake manifold. The front of the crank shaft has a square hole in the end about 3/4 inch square. I will attempt to post some pictures, after I figure out how to do that.
Alaska Mike is offline   Reply With Quote
Old 12-03-2016, 03:45 PM   #2
C26Pinelake
Default Re: Barn Find Help Me Identify
I would not miss a day of work to retrieve it! Wayne
C26Pinelake is offline   Reply With Quote
Old 12-03-2016, 06:53 PM   #3
700rpm
700rpm's Avatar
What's your question?
Ray Horton, Portland, OR
Old 12-03-2016, 06:57 PM   #4
eagle
eagle's Avatar
His question is: "Help me identify" pics to come later.
Old 12-03-2016, 07:31 PM   #5
Alaska Mike
I am sorry. I have uploaded the pictures to my album, but can't seem to get them to this thread. The questions I have concern the rather unique intake and exhaust manifolds. The exhaust manifold comes to the front of the engine and then straight up. The intake manifold is set up so that you could install and updraft or a downdraft carburetor. The front of the crankshaft has a 3/4 inch square hole in the center.
Hopefully someone might be able to help me figure out this picture thing.
Old 12-03-2016, 07:33 PM   #6
Alaska Mike
Hopefully the photos are attached.
Old 12-03-2016, 07:36 PM   #7
Alaska Mike
Two more photos
Old 12-03-2016, 07:48 PM   #8
modelAsteve
modelAsteve's Avatar
Yes- it has stationary power plant (saw mill) written all over it. Modified Model A intake manifold modified to take a down draft carb or use the stock up draft and the exhaust manifold flipped 180 degrees. Cut off torque tube in stock position.
modelAsteve is offline   Reply With Quote
Old 12-03-2016, 08:04 PM   #9
DaWizard
Send a message via AIM to DaWizard
Well, the tranny top is definitely mid '28 to '29. Is there a number on the boss on the left side?
New owner of '28 Tudor
Previously owned;
'30 Sport Coupe
'28 left brake ccPickup
'31 SW Town Sedan
'28 AA Stake Bed
'30 Cabriolet
'42 Super Deluxe 4door Sedan
"If it don't fit, get a bigger hammer.
If it breaks...... ya needed a new one anyway!!"
Doing a good job here is like wetting your pants in a dark suit.
It gives you a warm feeling, but nobody notices.
Never pass up a bathroom
Never neglect an erection
Never trust a fart
DaWizard is offline   Reply With Quote
Old 12-03-2016, 08:08 PM   #10
Alaska Mike
Thanks for all your comments!
Old 12-03-2016, 08:11 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
$50 to $75 if you want to gamble on it. You might get lucky, or you might be buying a boat anchor.
Old 12-04-2016, 12:53 AM   #12
Dave Mellor NJ
Has the finger on the universal housing that hooks onto the cross member, a 28 feature and the torque tube is rotated up so the radius rods' anchor is up. The square hole is for a crude power take off. i had one like that on a doodlebug
Dave Mellor NJ is offline   Reply With Quote
Old 12-04-2016, 01:14 AM   #13
DaWizard
Well, you can see the speedo output on the top of that portion of the torque tube.
I am a little concerned about the throw out bearing shaft coming out the right side of that bell housing and the pedal shaft coming out the left side. I would call it a RHD bell housing if I didn't know better.
Previously owned;
'30 Sport Coupe
'31 SW Town Sedan
'28 AA Stake Bed
'30 Cabriolet
Never trust a fart
Old 12-04-2016, 08:48 AM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
We used to flip intake manifolds, & modify them for different carbs, etc. NEVER even thought about flipping BOTH manifolds???
Folks built ALL kinds of contraptions, when Chief worked for the W.P.A, they even had a PILE DRIVER, on the back of an "AA"--- "Sawmill" trucks were common & some could be driven ANYWHERE, to cut lumber, ON site.
I was QUITE aware of the goings on, as my Grandpa was the local Master Saw Sharpener & Barber, also!
Bill Old
"THE ASSISTANT GURU OF STUFF"
Old 12-04-2016, 09:40 AM   #15
Beauford
I have a extra engine that looks just like this with the manifold correct and has a large mount for a 4-6" belt. It was used for a planer at a mill.
Beauford is offline   Reply With Quote
Old 12-04-2016, 04:21 PM   #16
eagle
eagle's Avatar
Inverting the exhaust manifold made much more sense as a stationary engine. Gets the exhaust heat and possible ignition point for dust off the ground. Easy to mount a tractor type muffler on it too.
Old 12-05-2016, 10:21 AM   #17
BILL WILLIAMSON
HEAT goes UP, so that should be a VERY efficient exhaust!
Bill W.
Old 12-05-2016, 12:23 PM   #18
Jason in TX
Jason in TX's Avatar
early ford turbo manifold
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
