Old 11-19-2016, 01:31 PM   #1
d.j. moordigian
d.j. moordigian's Avatar
Default very early, early and mid-28 steering box number
About a month ago, an early steering was found with what could be a serial
stamped on it. Two weeks ago another one was found. These are BOTH 2nd.
style columns for "no bale" or "open bale" type light switches. First style with
the small square Pittman arm shafts AND the third style WITH a bale are
included in this question. The numbers found are "15346" and "26040".
The numbers would be found at the BASE of the column on the TOP were the
4 bolts hold the lower bearing too the box.
These could be serial OR quality control numbers that Ford would use,..similar
to the "torque tube numbers".
It only takes a minute to check your 7 tooth columns. Do you have any with
numbers stamped on them?
Thanks, Dudley
https://www.fordbarn.com/forum/showth...bers&showall=1
d.j. moordigian is offline   Reply With Quote
Old 11-19-2016, 02:19 PM   #2
Ron in Quincy
Ron in Quincy's Avatar
Default Re: very early, early and mid-28 steering box number
Dudley,
The very early steering gear in my A1276, this is the steering that was in the chassis, has the numbers 25608 ,only in reverse of the numbers shown in your picture.
Another very early steering gear I have has no numbers stamped on it.
Ron
Ron in Quincy is offline   Reply With Quote
Old 11-21-2016, 10:42 AM   #3
d.j. moordigian
I should have add this information...
There are only two "steering gear housing" (that I know of)..
1. The early style with the weld down the center,top and bottom,...the weld is about
10" long.
2. The 2nd. style with NO weld..
You can rebuild either style too make an early or later column,...so you need to look
at what you have....so please look for the numbers and if early or late.
Thanks
Old 11-21-2016, 10:57 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
D.J,
If you use the wrong one, my lips are SEALED! We only have to wurry about the Dog blabbing!
Willy Bill
"THE ASSISTANT GURU OF STUFF"
Old 11-21-2016, 07:31 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I just checked my 9-27-28 Phaeton and two more 7 tooth, and all 3 have the welded seam and no numbers.
Old 11-21-2016, 07:59 PM   #6
DaWizard
Send a message via AIM to DaWizard
I just looked at my 7-20-28 Tudor and it only has the weld, no numbers
New owner of '28 Tudor
Previously owned;
'30 Sport Coupe
'28 left brake ccPickup
'31 SW Town Sedan
'28 AA Stake Bed
'30 Cabriolet
'42 Super Deluxe 4door Sedan
"If it don't fit, get a bigger hammer.
If it breaks...... ya needed a new one anyway!!"
Doing a good job here is like wetting your pants in a dark suit.
It gives you a warm feeling, but nobody notices.
Never pass up a bathroom
Never neglect an erection
Never trust a fart
DaWizard is offline   Reply With Quote
Old 11-21-2016, 08:29 PM   #7
iverson
iverson's Avatar
No numbers on our 6-21-28 touring is the weld where the screw driver is pointing?
iverson is offline   Reply With Quote
Old 11-21-2016, 09:31 PM   #8
Charles Reese
Charles Reese's Avatar
Jan '28: welded; 'square' boxy style; 1 alemite on top of case, none on sector case; no bail light switch ... no numbers
Charles Reese is offline   Reply With Quote
Old 11-21-2016, 11:15 PM   #9
Tom Wesenberg
The weld on all of mine is up and down the main steering box part, so it would run through your grease zerk.
Old 11-22-2016, 01:05 AM   #10
Tom Wesenberg
I just came across a 4th one, which is different from my other 3. This one has no weld seem, has 2 grease fittings, and no numbers. It's probably the same as the one in #7, if that one has 2 grease fittings.
Old 11-24-2016, 01:23 PM   #11
frankfalcone
February 14 1928 2 door sedan number 24981 steering column number 14678. There is no weld seam, one grease fitting on the top. Light switch rod engraved "on-off-dim". No bail or drain hole with knurled cover. The education never stops on these early Fords seems the list of early features is never ending.
frankfalcone is offline   Reply With Quote
Old 11-26-2016, 03:15 PM   #12
d.j. moordigian
Thank you for the help and information.
It's interesting that the steering box, on such an early car, with all the early
features, doesn't have a weld seem. Maybe someone ground / filled the seem
to make it look nicer.
Hopefully the new revision will have a date on the change from the 2 piece
too the one piece steering box. I do have a call into a Senior Judging Standards
member with the question
Old 11-26-2016, 07:45 PM   #13
frankfalcone
The 2 door sedan number 24981 is a original car that was not run for 57 years when I bought it. The early parts were all there I even have the original interior with only a small wear spot in the front carpet. I didn't have to do anything to the steering column original wiring still working great .This car is a time capsule of how early Fords were put together.
Old 11-30-2016, 04:39 PM   #14
plind
plind's Avatar
I have one on my Sports Coupe * A17188 * It has a number in 14540 on same place , and no welding.. It is the orig sterring , I can not post a picture.. I will try to send a mail to D.J Moordigian with 2 pic.
www.forda1927.dk
Tudor * A 2820 *
Town Sedan * A 4472283 * Orig.never restored.
plind is offline   Reply With Quote
Old 12-03-2016, 01:32 PM   #15
d.j. moordigian
I thank you for your help!
This information is not for me,..it will sometime, maybe be, in the next revision, for the
"Restoration and Guidelines and Judging Standards", IF more information is brought
forth.
They are now asking for photos of the welds and how they were finished. This would be
for the steering box with only one(1) grease fitting on top of the box.
Thanks,
Dudley
Old 12-05-2016, 01:33 PM   #16
Charles Reese
2 photos from Per Jensen's steering column (Sports Coupé *A17188*)
Old 12-05-2016, 01:39 PM   #17
Charles Reese
my Jan '28, no numbers, single lube port ... weld seems pretty well done (certainly better than i could accomplish)
