Old 11-20-2016, 05:35 PM   #1
Lawrie
Lawrie's Avatar
Default Stromberg BIG 97
Anyone using one of these,
I,m thinking of getting one for my 265 cuin 99a engine,stock cam and heads.
I currently use one 97 carb on in it. and think it may be a bit small,I have it in my 33.
Lawrie
Old 11-20-2016, 06:08 PM   #2
TonyM
TonyM's Avatar
Default Re: Stromberg BIG 97
I have this one.
TonyM is offline   Reply With Quote
Old 11-20-2016, 06:48 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by TonyM View Post
I have this one.
I believe he's talking about the NEW "BIG 97" as offered by Stromberg. They're 250 CFM. Click the link! DD
http://www.stromberg-97.com/carburetion/big97.asp
Click Links Below __
T5 W/TORQUE TUBE
Old 11-20-2016, 06:50 PM   #4
Mike in AZ
Mike in AZ's Avatar
maybe one of the carb gurus can chime in....Mike
Mike in AZ is offline   Reply With Quote
Old 11-20-2016, 07:23 PM   #5
uncle max
uncle max's Avatar
thank you, thank you, thank you
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 11-20-2016, 08:00 PM   #6
Lawrie
Lawrie's Avatar
Any one using one?
Lawrie
Old 11-20-2016, 09:03 PM   #7
Talkwrench
Talkwrench's Avatar
Maybe try PM felix37 he has one on Lawrie.
https://www.fordbarn.com/forum/showth...=Big+Stromberg
Old 11-20-2016, 09:26 PM   #8
Lawrie
Lawrie's Avatar
Thanks Rob, on a side issue,I just bought two sets of diff bearings at my local brg joint,all timkin and made in USA.
Lawrie
Old 11-20-2016, 09:51 PM   #9
Talkwrench
Talkwrench's Avatar
Praise the baby cheeses !! Guard them with your life.. USA made Timken would be like gold now...
Old 11-21-2016, 07:00 AM   #10
JWL
I can say the "BIG 97" was years in the making and has undergone serious research and development. It would be a good fit for any single carb installation such as you mentioned.
JWL is offline   Reply With Quote
Old 11-21-2016, 07:50 AM   #11
glennpm
glennpm's Avatar
HI,
I noticed that these are rated at 250 CFM. Does anyone know what the original 97's CFM is rated at?
Old 11-21-2016, 08:01 AM   #12
weemark
Originally Posted by glennpm View Post
HI,
I'm sure its about 155cfm.
weemark is offline   Reply With Quote
Old 11-21-2016, 08:02 AM   #13
glennpm
glennpm's Avatar
Thank you weemark.
Old 11-21-2016, 07:35 PM   #14
Talkwrench
Talkwrench's Avatar
Velocity...the correct word Im looking for?
What would be a flatheads volumetric efficiency be 75% at best?
Just mucking around doing the calculations Lawrie you could be just over 200CFM with a 265 CI.
BUT your towing a lot, I wonder how the lager CFM might effect your bottom end?
Hey if it doesn't work you could always send to me to try on my lightweight truck
; o P
Old 11-25-2016, 03:12 AM   #15
scooder
One thing to consider is how do the throttle openings of the big 97 match up to the carb mounting pad of a stock inlet manifold? I mention this as I know for a fact that a stock flathead intake (excluding the 8CM) don't have enough meat to open up to match a Rochester 2 gc.
Ain't worth doing if the intake is not opened up to match.
Cfm, what depression was the big 97 tested at to arrive at 250 cfm,
the normal published 150 cfm for a stock 97 is a figure that was tested at 1.5" not the usual 3" that is universal test depression for a 2 bbl carb. 1.5 is what 4bbls are tested at. So to compare flow twix 97 and Big 97 you need to test at the same depression.
Martin.
scooder is offline   Reply With Quote
Old 11-25-2016, 04:19 AM   #16
Lawrie
Lawrie's Avatar
Martin,I haven't looked at the manifold to see if there is enough meat to open up the bores.
And as Talkwrench says ,most of the driving I do in the 33 is towing our caravan (900Kgs) at around 50 mph with the 3.78 rear gears and 17 in tyres,so about 2100 rpm,it gets reasonable gas mileage it that ,about 18 litres /100 klms.
I know the engine would make more power further up the rev range ,but it hardley ever goes above 60 towing,
If I was,t towing I think a 3.54 and bigger carb would be useful,
Lawrie
Old 11-25-2016, 08:42 AM   #17
weemark
martin the big strombergs are not as big as rochesters 2barrel carbs. all the information about them is on clives web site http://www.stromberg-97.co.uk/tech_c...y.asp#techlist
Old 11-25-2016, 08:46 AM   #18
scooder
Thanks for that link Mark,
Will have a butcher's.
Martin.
Old 11-25-2016, 04:17 PM   #19
scicala
scicala's Avatar
It's too bad they didn't standardize the carb flow depression between all companies. When I worked at Zenith carburetor in the engineering lab years ago, we flowed the carbs at a 2" hg depression. Makes it hard to compare apples to oranges unless you have you're own flow bench.
Sal
scicala is offline   Reply With Quote
Old 11-25-2016, 06:28 PM   #20
Jim in Wisconsin
I have a Stromberg carb that seems to be the same as a 97, except it says "1 1/32" on the side. That would be about 1/16 bigger venturi - would that be considered a "big 97"? I don't know what the carb is from, I bought it at a garage sale.
Jim in Wisconsin is offline   Reply With Quote
