Does anyone have the step by step article or instructions on making the necessary modifications to make the carburetor Air pressure balanced?
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
If somebody with that Info sends it by PM, please include me.
I'd like to know too.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
MAFCA magazine Restorer had that in one of their issues about 6 years ago if anybody has an index it could be found.
Do a search for Air balancing Zenith carburetors, using a larger air cleaning is a way around the problem.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
Chris Pelikan did a lot of research on the subject of the need for air balancing ... Here are his thoughts:
http://www.modela.org/filtering_air_into_carb.html |
'31 180A |
Nov/Dec 1994 pg 17. The Restorer
www.whidbeymodelaclub.com |
Someone posted this picture a while back. You can see the vent hole is filled and the lower carb body and venturi are modified. I can only speculate that a 'port' is drilled in the body leading to the carb throat by the choke butterfly?
If I remember correctly this is how Renner's modifies the Zenith. ![]() |
If I wanted to add a balance tube, I'd buy a thin brass tube from the hobby shop or hardware store that fits tight into the air vent hole. It only needs to be about 3/4" long. Then slip a piece of tubing over the brass pipe and have it enter anywhere between the choke plate and air filer. This way you can have a balanced carb for an air filter without doing any cutting or drilling to the carb.
