Old 09-05-2016, 12:22 PM   #1
crazy redneck
Default 12 volt
I have changed a 9n ford tractor over to 12 volt alternator.I put on a 12 coil,but it wont hit a lick.Do i need to replace the condenser?It ran fine before.I ran a wire from the battery to the coil,still nothing.Please help!
crazy redneck is offline   Reply With Quote
Old 09-05-2016, 02:44 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 12 volt
The coil mounts on the distributor did you change to a adapter ? make sure the spring contact is engaged. Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
