Old 09-05-2016, 10:04 AM   #1
Licensed to kill
Licensed to kill's Avatar
Default Keeping the windows up
Im find it rather annoying that the windows creep down when driving. I oriented the handle so it's at about 4 o'clock when the windows are up so the weight of the handle has to be overcome for the window to creep down. Might have helped a LITTLE but not really. I Have to get new windows cut and was considering getting them 1/8" wider to perhaps give them more drag. Any thoughts??.
Licensed to kill is offline   Reply With Quote
Old 09-05-2016, 10:34 AM   #2
wrndln
Default Re: Keeping the windows up
You might have a weak or broken spring on the window regulator. You might try to replace the regulator (or spring) and see if that helps.
Rusty Nelson
Old 09-05-2016, 11:02 AM   #3
Licensed to kill
Some of the regulators are new and the problem exists in all four windows in the '29 Tudor and both windows in the '31 pick-up.
Old 09-05-2016, 11:05 AM   #4
Glenn C.
Glenn C.'s Avatar
You might end up with more problems than you anticipated, when you get new glass cut. The original glass thickness is thicker than the new glass. From what I understand, the original was 9mm, where the new glass is 8mm. Along with that problem, you will need to replace your window felts, and probably install some extra shimming to tighten up on the side of the glass. One of the suppliers several years ago sold precut window glass, that claimed it was correct for the Model A. Possibly 12 years ago.
Don't make them too tight, as you may also find that the window cranks won't stand up to the extra strain, as a lot of them are only pot metal.
Glenn C. is offline   Reply With Quote
Old 09-05-2016, 11:10 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
Sounds to me that the regulator springs are not 'wound' tight enough. It's strange that all of your windows have the same issue...
Old 09-05-2016, 11:13 AM   #6
Licensed to kill
Yes, the thickness of the glass is an issue. None of glass is original and all of the felts are new. I never consider the spring winding. I wonder if they can be wound one more turn???
Old 09-05-2016, 12:38 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
The regulator has a locking spring to prevent the handle from turning until the handle is turned by hand. It does seem odd that all 4 would be bad at the same time though.
Old 09-05-2016, 01:22 PM   #8
Kevin in NJ
Which body? Straight window or slant?
Original or repro?
The square part that the handle is put on also has a clever brake system. There is a spring that is wound up and pressure from the handle causes it to twist and get smaller so the handle will turn. The glass putting back pressure on the spring causes it to expand and stop the glass from falling down. Not sure about the straight window types, but the slants are notorious for breaking.
So you have a couple of things to look at with the helper springs and the brake springs.
Old 09-05-2016, 01:39 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Chief used to fill a Bull Durham Tobacco sack with gravel & hang them on the window winder goody, to keep them closed !
Also, on a'35 International P.U, he "crafted" a stick, to hold it in HIGH gear! He had a lots of "tricks"!
Chiefs' Son
"THE ASSISTANT GURU OF STUFF"
Old 09-05-2016, 02:32 PM   #10
C26Pinelake
Chiefs' Son
Sounds like Chief was a very ingenious person! Wayne
C26Pinelake is offline   Reply With Quote
Old 09-05-2016, 03:59 PM   #11
mccsix
mccsix's Avatar
My farmer fix was small wood wedges wrapped in black cloth tape push in between glass and molding.
Gene
USN
mccsix is offline   Reply With Quote
Old 09-05-2016, 09:33 PM   #12
C26Pinelake
They actually sold small rubber, ribbed wedges to stop the window from descending and they were also used to stop rattles. Wayne
Old 09-06-2016, 12:10 AM   #13
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Kevin in NJ View Post
Original or repro?
You know my vote!
Old 09-06-2016, 09:13 AM   #14
Licensed to kill
Thanks for all the replies. There is certainly a few things that i can check out.
