Old 08-25-2016, 04:36 PM   #21
weemark
Default Re: 97 Carb Fuel Bowl
Originally Posted by Bulligen View Post
Every line is brand new as well. This is why its driving me nuts!
Being brand new doesn't mean they are working as they should though. Given this issue happened when your old carb was on I would say discount the new carb and move onto the next item in the chain and keep going until you have found your culprit.
weemark is offline   Reply With Quote
Old 08-25-2016, 10:28 PM   #22
Bulligen
Bulligen's Avatar
Ok , I set op a gravity flow fuel tank under the hood. It runs fine other than adjusting the idle screws! So then I put a gauge on the fuel line coming from the main tank , turned the pump on and it says a little over one pound ! Tomorrow night the story continues !! I will hook it back up with the electric fuel pump and see what happens?
Bulligen is offline   Reply With Quote
Old 08-26-2016, 12:52 AM   #23
weemark
That's got to be good news because it's not your new carb which is faulty - your old carb probably isn't faulty either though. At least you have a good spare now
Old 08-26-2016, 08:08 AM   #24
Bulligen
Bulligen's Avatar
You are so right, and I finally got to drive the car around the block!
