Old 07-29-2016, 12:27 PM   #1
mrtexas
mrtexas's Avatar
Default Radiator yoke mounting kit
I bought from Roy Nacewitz thinking I was getting the bolts/springs that attach the radiator to the frame. I got R-62-02 radiator yoke mounting kit. I can't remember taking one off when I took apart my 41 woodie.
Can someone describe/post picture where it goes?
Picture shows the yoke bolt next to the smaller radiator bolt
mrtexas is offline   Reply With Quote
Old 07-29-2016, 12:34 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Radiator yoke mounting kit
Radiator mounting bolts. Pads go between rad and frame then bolt ,spring and nut.
Old 07-29-2016, 01:07 PM   #3
19Fordy
19Fordy's Avatar
Could that "Yoke" bolt may be for the "Y" bracket yoke that bolts to the front cross member on 40 Fords? It looks bigger. I remember removing a bolt and spring set up that was similar to the radiator bolts when I removed that bracket years ago.
Old 07-29-2016, 01:56 PM   #4
Ken/Alabama
I think your correct. I saw two in the pic and assumed they were for the radiator but after taking a second look I'm seeing one new one.
Old 07-29-2016, 03:03 PM   #5
mrtexas
mrtexas's Avatar
Yes that is it. My car didn't have a spring in it when I took it apart a while back.
Talked to Roy Nacewitz and he was helpful as always.
Green book p349 lists 3/8 bolt for 42/48.
Roy lists and supplies p19 7/16 bolt for 40/48
My 41 takes a 3/8 bolt just like the radiator hold down bolt.
I'll return what I have and Roy will supply a 3/8 bolt setup.
