Hello! I am wanting to use the 32-34 spindles because of the integrated steering arm, but would like to use 36 wide five drums. I know 36 wide 5's have a longer outter bearing snout that 37-39.
Think I'll run into an issue? I'll be using 39 Lincoln backing plates with the spindle bolt spacing adjusted for the 32-34 spindle, so backing plate is no problem. Thanks!
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
They should bolt up fine.
Thee Inland Emperors |
Jason, here is a discussion a few days ago. Ed
https://www.fordbarn.com/forum/showthread.php?t=200312 |
Get in touch with Richard Lacey at Early V8 Garage. Just run everything by him. He helped me with my project. I am running early spindles with the 1936 wide five drums. I am using original 1939 Lincoln backing plates also. I have the original brake drums if I ever want to run wires. |
