Old 06-20-2016, 07:31 PM   #1
trevo
Default 34 flywheel pilot bearing
What is the dimensions of the bearing does anyone have an SKF or Timken number for it thanks info appreciated
trevo is offline   Reply With Quote
Old 06-21-2016, 01:57 AM   #2
scooder
Default Re: 34 flywheel pilot bearing
From memory it's 40mm od, 17mm id, 10mm or 12mm deep.
Yes it's a metric size!
Can't check one right now, so hopefully someone will spuddle along with the confirmed size.
Martin.
scooder is offline   Reply With Quote
Old 06-21-2016, 05:23 AM   #3
flatheadmurre
flatheadmurre's Avatar
From that meaasurements it´s a 6203.
ending with 2z for metal or 2rs for plastic dustcovers.
Old 06-21-2016, 07:02 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
There are many variations available of this basic bearing. I would suggest finding one that has high temp grease, and is sealed on both sides. The seals are usually made of a soft rubbery plastic material, that is sometimes reinforced with sheet metal. The versions with plain sheet metal covers, aka "shields", are not dust sealed, and you really need a sealed pilot bearing rather than one that just has the shields. Originally, Ford used pilot bearings that were open face or shielded, and these bearings usually failed from loss of grease and dust/dirt contamination.
John
Old 06-21-2016, 08:50 PM   #5
v8fordman
v8fordman's Avatar
Go to your local bearing supplier. starter/generator rebuild shop, parts store or transmission shop and ask for a "203" bearing. It is very common and should be only a few dollars. Many manufacturers may use the part number 6203, but your supplier will understand 203. Make sure to get one sealed on both sides and you may want to check to see that there is plenty of grease behind the seal. It just snaps in and is no trouble to remove and reinstall.
v8fordman is offline   Reply With Quote
