Old 05-14-2016, 09:46 AM   #1
Cape Codder
Cape Codder's Avatar
Default Smoking generator
Have a running generator which was on the car. Started to smoke so I removed it and replaced with a known good generator. Question: Is the generator unrepairable? What checks can I make now to determine what is wrong?
Cape Codder is offline   Reply With Quote
Old 05-14-2016, 09:51 AM   #2
Bob C
Default Re: Smoking generator
Just refill it.
Bob
Old 05-14-2016, 09:51 AM   #3
Rowdy
Check the armerature with a growler and check the communtator with a multimeter from the segments to the shaft. There should be no continuity. Also check the field coils and make sure none are grounded. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-14-2016, 10:12 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Remove the field ground from the case, then use an ohm meter or continuity tester to make sure the field windings aren't grounded to the case. Then reconnect the ground and connect a battery charger + to the case and - to the field wire that goes to the adjustable brush. The battery charger (6 volt) should show about 4 to 5 amps draw. This will tell you the field windings are OK, but you need a growler to check the armature.
Most likely the generator was putting out very high voltage due to a bad connection between the generator and battery. If you use an electronic voltage regulator, a bad connection isn't going to smoke the generator, but without an EVR the generator will run wild without the battery to control the voltage.
Old 05-14-2016, 10:12 AM   #5
Cape Codder
Rowdy - Thanks very much for your response. Appreciate the information.
Old 05-14-2016, 10:23 AM   #6
Cape Codder
Tom Wesenberg - And Thanks to you also for the information. Off to the garage to check it out. Sure appreciate your response.
Old 05-14-2016, 11:45 AM   #7
Cape Codder
Well I opened up the case of the generator and found this. I also noted a VERY distinct order of burned electrical wiring or...........
Old 05-15-2016, 12:47 PM   #8
Cape Codder
I thought I would have gotten a few comments of advice from the picture I attached.
Any one?
Old 05-15-2016, 01:10 PM   #9
Tom Wesenberg
I wrote something but it didn't post. The picture is a little out of focus, and I can't tell much from it. I would have it tested on a growler. Also use an ohm meter to see if the commutator has contact to ground. There should be NO contact between any commutator bar and the shaft.
Old 05-15-2016, 06:21 PM   #10
jax55
jax55's Avatar
I can't really tell from the picture either, but was the armature hitting the field coil or core?
If you lost a bearing or bushing, it would allow the contact, smoke and noise.
If it was not hitting, follow Tom's tests... even if you do find the contact, do the other tests too.
jax55 is offline   Reply With Quote
Old 05-15-2016, 07:59 PM   #11
Cape Codder
Thanks to Tom and jax55. I actually agree with you guys about the picture not being focused but........it was the best one of several I took. Maybe I need to fix the camera first LOL!!! I will do what you guys suggested tomorrow.
Thanks again!
