Old 04-21-2016, 12:41 PM   #1
Mac_4
Mac_4's Avatar
Default 1930 Tudor.....Nuts & bolts
Hi there,
My Model A Tudor is in bits and I'm trying to put it back together. Does anyone know what size nuts and bolts I need to mount the rear fenders.
Thanks
Sent from my SM-N910F using Tapatalk
Mac_4 is offline   Reply With Quote
Old 04-21-2016, 12:50 PM   #2
CarlG
CarlG's Avatar
Default Re: 1930 Tudor.....Nuts & bolts
I have found this book to be a valuable aid in determining what bolt to use where:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-21-2016, 01:00 PM   #3
C26Pinelake
The book above is a must for you! Wayne
C26Pinelake is offline   Reply With Quote
Old 04-21-2016, 02:12 PM   #4
Mac_4
Mac_4's Avatar
That's great Carl thanks. I'll get one on order. In the meantime do you know what size fasteners I bed for the rear fenders on a 30 sedan?
Old 04-21-2016, 02:24 PM   #5
captndan
captndan's Avatar
Also check with the better known suppliers. They have nut, bolt, screw kits for most stuff. Much cheaper and better than the local hardware store.
captndan is offline   Reply With Quote
Old 04-21-2016, 02:31 PM   #6
31Tudor
31Tudor's Avatar
I don't have the info in front of me, but I believe it is 5/16" fasteners. Starting at the running board, There are two carriage head bolts (heads to the wheels) then lockwashers and nuts. Then the next two bolts up fender to splash apron- 5/16 bolt, flat washer, metal pieces then flat washer, lockwasher and nut. Then there are 4 studs- fender, flat washer, lockwasher and nut. Then the fender bracket is held on with a couple fine thread bolts and lockwashers. This info will get you close. If no one else has more info I can double check judging standards tonight.
31Tudor is offline   Reply With Quote
Old 04-21-2016, 02:50 PM   #7
CarlG
CarlG's Avatar
I don't have the book handy to me here at work. If you haven't been able to determine what you need, I'll try and remember to look it up later tonight.
Alaskan A's
Old 04-21-2016, 02:58 PM   #8
Mac_4
Mac_4's Avatar
Thanks if you don't mind. I won't be able to go near my car until Saturday now and it would be nice to grab the fasteners tomorrow. No worries if you can't👍
Old 04-21-2016, 03:00 PM   #9
Mac_4
Mac_4's Avatar
Thanks. I'm a metric man and am struggling!
