I am going to run out to the LA Roadster show with a bunch of guys from Smithfield, VA of which there is a thread in the HAMB. I will be gone 3+ weeks, so I thought I would chronical everything here on the 'Barn starting with the prep of my roadster up until the day I return home. Something like I did on my run out to Bonneville but do it here this time.
So, to get started, another 'Barner, Gabby here on this forum, Earl, will be riding shotgun. I have started getting my roadster ready. I have a list ..... Different wheels and tires Oil, filter, grease Plugs and wires Paint my hood Run through every nut and bolt Drain the rearend Adjust brakes, check brake fluid Fresh antifreeze (thermoscwere replaced last fall) Pack all my spare parts Water pumps Distributor Tools, rear axle puller, spare axle, axle keys Grease, fresh set of plugs Yamalube Cleaning supplies Spare starter, starter solenoid Spare carbs, rebuilt kits Full gasket set, fuses Extra gas lines, electric fuel pump, fuel regulator Spare oil, brake fluid, antifreeze, grease gun, rainex Jumper cables, tarp for rainy o-nights Floor jack, jack stand, lug wrench, fire extinguisher Jumper cables, hand cleaner, rags, towels OK - by now you are probably wondering where an I going to put all this stuff?!?! So, tires - I have a fresh set of wheels and tires ready to go but they are wide five and I am presently running 5.5 inch pattern. My present tires are showing some wear up front after 8 years or so of driving. So, in order to use them on my car I bought a set of adapters from American racing for the front f100 hubs and I have a nice set of wide five rear hubs. This stuff is all for a Mod A p-up project that is presently on the back burner. A buddy of mine has a set of '37 spider caps that I have cleaned up but have plenty of patina ... Next up is to install them and order some new cloth wires .. . |
That's quite a list Tom. But that should be a nice trip. Good luck to you. Hope to see you there. Mark.
Hey, Mark - let's make a day and time and you are on ....
watching this space...
"Came too close to dying to stop living now!" |
Tom,
Just remember all the extra stuff you packed for the Bonneville run was used on other peoples cars. The roadster performed almost flawlessly. Tighten this tighten that was all it needed. Safe travels to LA. That should be a fun trip. I'll be following from the barn.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
Sound like a truly wonderful adventure. A memory to have and share for a life time.
Hope your trip goes smooth and enjoyable. I look forward to seeing your posts about the trip. Are you hooking up with the "Gray Beard" group? Have fun Bill Herbert |
Tom, you are living the dream and I'm looking forward to reading the posts. Safe travels. Steve
If it aint broke, don't fix it! |
Tom,
Why don't you publish your route using a map program. That way if something breaks along the way and you need a tool or tow we can help. I did a cross country in an AH Bugeye Sprite in my youth - not good for the sunburn,back or knees but it was fun. Good luck! |
Run Tom Run!!
Stop by here if I am on your route. I always left out of Phoenix way before dawn for the final leg. Going across the desert at dawn with a long shadow of the roadster chasing ahead of me was always great. I used to call Palm Springs the valley of death because of the heat, especially if returning Sunday evening. Take a cooler with water.
Be sure and take some matches and a small mirror. You never know....
And, if you have a permit to carry, make sure it's legal in all the states you enter. https://en.wikipedia.org/wiki/Concea..._United_States |
#13 |
Tom,
All I can say is, "Have way too much fun, okay?" |
#14 |
Thanks for all the offers and kind words, fellas. As far as the route out to the show, we go west on 460, hit rt 81 south then on to Rt 40 west for the long haul to Calif, taking Rt 10 to San Dimas and our hotel. I will post where we'll be stopping roughly as we get closer. Coming back we are kind of winging it, probably taking in more of Rt 66 west of Missouri, a stop in New Mexico, and hopefully meet up with as many like minded people as we can .....
Just an quick update on my wheels and tire setup. 3 spider cap clips were broken off on my rims. I got the replacement kit and Dave at House of Fab had a rivet tool and popped the three on for me. Tomorrow is my Dads 92nd birthday so Sunday will be the day for the mounting, and draining and refilling the rear end fluid ... |
#15 | |
![]() Quote:
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
#16 |
Enjoyed the Bonneville trip with the boners. You put some miles on her that time . Your reports on the trip home were great !
#17 |
Thanks, Pipes - I will try and do the same this time around!
And Max, thanks for the reminder - I think?!?!?! |
#18 |
spare tire/tubes??....tire pump??....hook up with Al Casteen as he's making the run, too....not sure of his dates, tho.....and have fun....Mike
#19 |
Hey, Mike - I am going with Al Casteen and the gang. No, the only thing I don't carry is a spare. With everything else I carry, there is no room!
#20 |
Have a blast Tom, sure wish I was going with ya.
Imagination is more important than knowledge. |
