Old 02-14-2016, 03:49 PM   #1
pooch
pooch's Avatar
Default 28 roadster quarter panel line of sight
Playing with roadster fibreglass rear quarters...28 - 29.
I would like to know how straight (or if it is reasonably straight ) from door B pillar ( A in pic) to the outside at the rear side C.
Bit ambiguous I know, but as glass could be any shape and it is a floppy body , I want to know if the subframe (also fabricated , not original to go by ) needs a kink in it or not.
A brookville or an original quarter off the car would give me a good idea.
Line I would like to know more about is in this pic.
Say, with a string line from ends of blue line A to C , how far in or out is a point at wheel arch front B ?
Or a pic would be good from rear along this lower edge ..
Also, is there a curve outwards or is it reasonably straight at the lower swage line where purple arrow is ?
pooch is offline   Reply With Quote
Old 02-15-2016, 10:40 AM   #2
Tinbasher
Tinbasher's Avatar
Default Re: 28 roadster quarter panel line of sight
It moves in a little from A -B maybe 1/2". The rear crossmember will give you C. The sub-frame will also give you the line. unless your building all of this from scratch. Drop me a line with more info and I can send you some pictures of different projects dealing with what you're up to.
John Poole
Tinbasher is offline   Reply With Quote
Old 02-15-2016, 12:05 PM   #3
Flop
All I have handy . Don't know if the pics will help or not .
http://www.jalopyjournal.com/forum/t...8-ford.959305/
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 02-17-2016, 03:41 PM   #4
pooch
pooch's Avatar
Thanks all .
My left hand quarter is the worst.
My aim is to force the floppy into place and make a re-mould of both quarters.
Nothing worse than having to have the same bad fit with every panel that comes out of the mould.
I guess the same old - same old repairs you have to do to every single brookville body must be a real chore too.
At least, a glass mould is cheaper than new dies .......
