Looking at one for a friend and other than adding the toolkit over the front splash guard, I can't figure out where to keep the Jack, extra belts and bulbs, etc.
Doesn't have a rack or steamer trunk. Thanks
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
Registered User
you can lift the rear seat and theres quite a bit of room under it
only trouble is that raising and lowering the seat wears the side panels out tom |
Yes, I believe you can remove the seat cushion and put stuff under the seat. There is not a lot of room, but enough to get some stuff in the space.
Rusty Nelson |
Good place for the crank , jack, & other stuff I don't need on a regular basis as my rear seat bottom doesn't tuck in place easily .
When u check out the car remove the rear seat bottom to look down in the quarter body pockets with a flash light for rot, half ass panel repairs etc...
#6 | |
![]() ![]() ![]() Last edited by Y-Blockhead; 01-27-2016 at 02:30 PM. Reason: Add Picture |
#7 | |
![]() Quote:
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
With my '29 Tudor I removed the rear seat and built up a compartment with what looks like a 1 x 8. I put a piece of plywood on top of that for a seat. With foam cushions on that, it makes a reasonably comfortable ride for rear seat passengers. I have good shocks. Lots of storage room for spare parts, tools, and flea market purchases.
In the 5 years I have had my rig, it has been hand cranked once -- just to say we did it.
I seldom raise the driver seat so the tool bag, crank and jack all fit under it. I don't carry a lot of stuff with me but if I did, it would go under the rear seat.
#13 |
But Ray since you are so concerned about me to inquire, I carry one of these when I venture too far from home
![]() http://www.costco.com/Lithium-Jump-S...100230151.html in here with the rest of my tools... 'just in case' ![]() ![]() ![]() |
#14 |
Yes, I have my crank, some tools jack etc.. not large but better than nothing..
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
#15 | |
![]() Quote:
#16 |
#17 |
To carry a crank is good,, but if you think you might have a problem starting , look for a place to park where you can roll it off.
#18 |
That Lithium charger says it is for 12 volts.....will it work to jump a 6volt Model A safely?
#19 | |
![]() Quote:
My Town Sedan was converted to 12v before I bought it but still had the 6v starter. 12v didn't seem to hurt the 6v starter. I have just recently put 12v Field Coils in my 6v starter. I have never had to use the Lithium Jumper on my car. Sorry roccaas. I didn't intend to hijack your thread. |
#20 |
Under my 29'Tudor rear seat I kept a bottle jack, chocks of wood for the front wheels when jacking, a spare carburetor,distributor, head gasket and sealer, water pump, plugs, condenser,points,fuses and the original tool kit and also a modern tool kit with 1/2 inch drive sockets and drive handle. Also duct tape and wire. I kept the crank under front seat so it was handy if needed. Never needed any of that stuff except a fuse one time in 28 years.
