Old 01-26-2016, 02:10 AM   #1
Jay in Mass
Default 59AB vs 8BA flywheel
How do you identify a 59AB flywheel against an 8BA?
Jay in Mass is offline   Reply With Quote
Old 01-26-2016, 02:49 AM   #2
scooder
Default Re: 59AB vs 8BA flywheel
An 8BA has clutch bolts clear through the flywheel, the 59a And earlier has blind holes.
Martin.
scooder is offline   Reply With Quote
Old 01-26-2016, 08:41 AM   #3
Binx
Also, the flat type flywheel used from 1941-48 is roughly 7/8" thick compared to the 8BA type flywheel at about 5/8" thick.
Lonnie
Binx is offline   Reply With Quote
Old 01-26-2016, 11:22 AM   #4
Jay in Mass
Thanks Martin and Lonnie
What I'm especially looking for is if there is a actual difference in the ring gear that is used on these two flywheels and what is it? I know that they will bolt onto both engines, but the wrong one will hang up the starter drive.
Old 01-26-2016, 11:33 AM   #5
JSeery
JSeery's Avatar
The ring gears are different diameters, but it is the inside diameter that is different. The difference you are referring to is in the flywheel itself.
Old 01-26-2016, 12:18 PM   #6
cas3
heres more : https://www.fordbarn.com/forum/showthread.php?t=187692
Old 01-26-2016, 09:39 PM   #7
Jay in Mass
JSeery and cas3
The link that was posted makes it perfectly clear that there is a difference in the inside diameter of the ring gear on the 59AB and the 8BA. Now I see it. Thanks.
Old 01-27-2016, 01:26 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Jay in Mass View Post
JSeery and cas3
Here's a pic that may help to visualize all the good info above. Note especially the clutch holes drilled all the way thru on the 8BA wheel. Also, ring gear height comparison makes it clear why starters don't work well with late wheels on early blocks, or early wheels on late blocks. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-27-2016, 02:06 PM   #9
Ronnie
Ronnie's Avatar
You can't install a ring gear on the wrong flywheel they don't interchange they don't fit each other due to sizing. Don't over think this.
R
Ronnie is offline   Reply With Quote
Old 01-27-2016, 04:38 PM   #10
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
That's a good picture for those that don't know what there looking for. Some people are looking for a flywheel but don't what there looing for. With that pic they can see the difference in the width of the ring gear. Once you've seen the difference you won't forget it. Walt
Old 01-27-2016, 11:54 PM   #11
Jay in Mass
V8COOPMAN
That picture of the 59AB and 8BA sitting next to each other makes it even better to see the difference.
Walt
Some day I hope to meet you. Do you still attend the Gathering of the faithful in Mass? I was a friend of Paul Howard. He was a great guy and perfect gentleman. Jay
