Old 12-03-2015, 09:01 AM   #1
JohnB15632
JohnB15632's Avatar
Default 31 Model A SW Town Sedan Project
Many of you have told me to keep pictures of the project to know how to put it back together. In my case, I have nothing but a body shell. Little to start with. Here are a few pictures of the body as I start to restore it. Chassis pictures to follow.
JohnB15632 is offline   Reply With Quote
Old 12-03-2015, 09:15 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: 31 Model A SW Town Sedan Project
John you have the makings of a great car. I have seen people start with a lot less and in a lot worse shape.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-03-2015, 09:29 AM   #3
Jeff P. / MN
Jeff P. / MN's Avatar
The only 'body off - ground up' restoration I have done was a 160-B sedan, a very nice and comfortable car to drive. Good Luck and keep us posted!
Jeff P./MN
1913 Model T Runabout
1926 Model T Sport Touring
1948 Chrysler New Yorker
Jeff P. / MN is offline   Reply With Quote
Old 12-03-2015, 10:01 AM   #4
burner31
burner31's Avatar
Seems to be an early '31, non-indent firewall.
Also seems someone cut a hole for a heater at some point in the past.
Since you have the body off check the vehicle stamp on the frame. located on the top of the frame rail, drivers side, near the battery area, there may also be a number stamped on the floor near the the driver's door opening where your left foot would be resting.
Both may be hard to read, use a bright light at different angles.
Running your numbers can help you zero in on what model (A,B,C) you have there.
It had cowl lights at one time, so I'm leaning towards "B"
Keith
Shawnee OK
'31 SW 160-B
Old 12-03-2015, 10:08 AM   #5
JohnB15632
JohnB15632's Avatar
Thank you. I already have. I have been successful in getting a title for the vehicle from PennDot. Pennsylvania Department of Transportation. I luckily found a AAA representative how had done this in the past. She told me the procedures step by step. I went before a judge and was out within 15 minutes. I have a titled vehicle!!!!!!
Old 12-03-2015, 10:08 AM   #6
burner31
burner31's Avatar
Look at your roof wood, the location of the dome light wood block can tell you a lot about the car also.
Keith
Shawnee OK
'31 SW 160-B
Old 12-03-2015, 10:10 AM   #7
burner31
burner31's Avatar
Titled as a A, B, or C?
Keith
Shawnee OK
'31 SW 160-B
Old 12-03-2015, 10:27 AM   #8
JohnB15632
JohnB15632's Avatar
It is a "B"
Old 12-03-2015, 01:17 PM   #9
lakeside
This is not a criticism,in any way, just wondering. Have you thought of restoring a car that was more complete and in better condition, considering the cost of the missing parts and the labor involved? I went through this myself.
lakeside is offline   Reply With Quote
Old 12-03-2015, 01:43 PM   #10
JohnB15632
JohnB15632's Avatar
Considering that I got the car for free and I never undertaken such a project before, it seems like the perfect retirement project.
I think that I am fairly mechanically inclined. The chassis is nearly 75% completed.
I think that it is a good project.
Old 12-03-2015, 03:07 PM   #11
lakeside
Sounds reasonable to me. Best of luck.
Old 12-03-2015, 03:08 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, never turn down free!
Your car is coming along great.
My first Model A started as a $125 1929 engine from a swap meet, then a free chassis and tranny from my cousin's woods, then a $50 1929 Tudor body from a pasture. Nothing got done as I kept locating parts, then I saw a complete running 1929 Tudor for $2000, so I bought that. I wanted something I could drive right away, and that pretty well fit the bill.
Old 12-03-2015, 03:59 PM   #13
mshmodela
mshmodela's Avatar
John,
Great effort, I'm sure you're learning and enjoying your project... Thanks for sharing...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
