Old 12-02-2015, 01:52 PM   #1
Buds28
Default 28 Roadster door hinges
Okay I am new to Model A's and need help. I want to replace the doors on my 28, how do remove the hinge screws? Someone has already buggered up the slots in the screw heads a bit. I have tried to remove them with a screwdriver but had no luck.
Buds28 is offline   Reply With Quote
Old 12-02-2015, 02:09 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: 28 Roadster door hinges
Using an automatic center punch carefully punch the center of each damaged head.
Then using a left handed drill bit drill out the bolt then insert an easy out to remove bolt.
If your lucky the left handed drilling will spin the bolt out.
All of these tools can be bought at harbor freight for under $20.00
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 12-02-2015, 03:49 PM   #3
Flop
Weld a nut to the screw head . Heat breaks the corrosion . Also your favorite penetrating oil helps. Let the weld cool completely before wrenching on the nut. This is on a non painted car of course .
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 12-02-2015, 04:23 PM   #4
2manycars
2manycars's Avatar
I use an impact screwdriver. It comes with different sized bits, and one hammers on it while turning in the remove direction. It works wonders.
http://tinyurl.com/pyxvbje
2manycars is offline   Reply With Quote
Old 12-02-2015, 05:15 PM   #5
pooch
pooch's Avatar
Weld a washer thru the hole onto the screw head.
Then weld a nut to the washer .
Try to turn the nut almost immediately while it is still hot, but not hot enough to break off the weld, , just wait a few seconds .
pooch is offline   Reply With Quote
