Old 12-01-2015, 08:47 PM   #1
Great Lakes Greg
Great Lakes Greg's Avatar
Default Firewall holes: What is original.
Holes numbered 1 through 4. I don't think any of these are factory. Do you agree?
Great Lakes Greg is offline   Reply With Quote
Old 12-01-2015, 09:29 PM   #2
jw hash
jw hash's Avatar
Default Re: Firewall holes: What is original.
If you are going back to original. NON of the four hole are there originally. someone had installed a hot water heater there.
jw hash is offline   Reply With Quote
Old 12-01-2015, 10:47 PM   #3
J Franklin
J Franklin's Avatar
Someone did a nice job making the holes!
Old 12-02-2015, 06:15 AM   #4
JOHN CT
JOHN CT's Avatar
I had the same 3/4 in holes.I was thinking about replacing the firewall, looked it over and what a job to do that. So a friend suggested filling the holes with a gas weld with my amazement it worked. The holes filled in perfectly can't even tell they were there!
JOHN CT is offline   Reply With Quote
Old 12-02-2015, 11:24 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
You can use washers, and/or electrical box knockouts.
Old 12-02-2015, 11:27 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Even rubber pop in plugs look pretty well after painted.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-02-2015, 08:05 PM   #7
pgerhardt
pgerhardt's Avatar
How did you handle welding with the gas tank a few inches away?
pgerhardt is offline   Reply With Quote
Old 12-03-2015, 12:51 PM   #8
BILL WILLIAMSON
Well, apparently John did it SAFELY, he's still typing
Bill W.
Old 12-03-2015, 01:45 PM   #9
JonC
That's a good one
JonC is offline   Reply With Quote
Old 12-03-2015, 04:55 PM   #10
JOHN CT
JOHN CT's Avatar
Bill W.
The holes were far enough away from the tank. The top hole was about 3-4 in below the tank
Old 12-03-2015, 05:50 PM   #11
Farrell In Vancouver
Farrell In Vancouver's Avatar
You are lucky, I had fifty-three non-stock holes in the firewall/cab of my 31 AA 82B cab. Took a lot of fitting to clean them up. Apparently they ran some hydraulics off a pump mounted to the engine and the lines and wiring went through the cab to the flat deck. Silverlining was that all that leaking hydraulic fluid preserved the original wood quite nicely
Farrell In Vancouver is offline   Reply With Quote
Old 12-03-2015, 06:12 PM   #12
Bob Bidonde
Bob Bidonde's Avatar
Holes shown are original.
Bob Bidonde
