Old 11-25-2015, 07:36 PM   #1
1929
Default 16 inch wheels?
Does anyone else sell 16s besides Snyders?
1929 is offline   Reply With Quote
Old 11-25-2015, 07:43 PM   #2
ModelAMike1930
ModelAMike1930's Avatar
Default Re: 16 inch wheels?
Try Ebay they usually have used 16 wheels there..
ModelAMike1930 is offline   Reply With Quote
Old 11-25-2015, 07:47 PM   #3
1929
checked,just saw 17s, I was told not much of a choice with tires for the 17s.
Old 11-25-2015, 08:02 PM   #4
zzlegend
zzlegend's Avatar
How many do you want?
http://www.ebay.com/sch/i.html?_from...heels&_sacat=0
zzlegend is offline   Reply With Quote
Old 11-25-2015, 08:10 PM   #5
1929
Originally Posted by zzlegend View Post
five, but when you see a good set its usually local pick up only. Who sells new ones?
Old 11-25-2015, 08:22 PM   #6
glenn in camino
glenn in camino's Avatar
They will make your Model A look FUNNY.
Old 11-25-2015, 08:24 PM   #7
1929
It looks funny now
Old 11-25-2015, 08:53 PM   #8
zzlegend
zzlegend's Avatar
Maybe this???????????????????????
http://www.wheelvintiques.com/wheels...re-primer.html
Old 11-25-2015, 09:18 PM   #9
1929
I think I called them a few months ago and I was told they wouldnt fit, I think because of the drum. Thanks for the info.
Old 11-25-2015, 09:50 PM   #10
Charlie Stephens
Put a wanted ad in the newsletters of the local Model A and Early V8 Clubs Also hit the swap meets. I assume you are looking for the 1935 Ford wire wheels (or maybe Kelseys). You are not looking for solid wheels are you? Remember that the 16 inch Ford wire wheels or Kelseys go on the mechanical brake drums, if you have hydraulic brakes you will need an adapter. You also need an adapter to run the later solid 16 inch wheels on mechanical brake drums.
Charlie Stephens
Old 11-25-2015, 09:59 PM   #11
1929
Charlie Stephens
No, not looking for solids, have the mechanical brakes. thanks Charlie
Old 11-25-2015, 10:42 PM   #12
C26Pinelake
Originally Posted by 1929 View Post
It looks funny now
It will even look funnier! Right now it looks like it should! Wayne
C26Pinelake is offline   Reply With Quote
Old 11-26-2015, 02:45 AM   #13
Charlville
Charlville's Avatar
I think mine looks lovely on 16"'s, but as always it's a matter of choice, mine were already fitted when I got the car.
https://automotiveamerican.files.wor...7/dsc_0034.jpg
HAMB often a good source
http://www.jalopyjournal.com/forum/t...#post-11221669
http://www.jalopyjournal.com/forum/t...t-of-5.970671/
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 11-28-2015, 10:51 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
18" 1932 wheels look better.
Bob Bidonde
Old 11-28-2015, 11:11 AM   #15
ronn
I see you are in NY-Tony Martino always has some and is in NY
I have a pair with roller tires if interested- I am in NJ and in Syracuse about once a month
pm if interested
[email protected]
Old 11-28-2015, 12:59 PM   #16
Charlie Stephens
My guess (based on Southern California wheels) is if you find a wheel there is about a 20% chance you can paint (powder coat) it and use it without any work. Another 60% can be straightened if you have the right equipment or find someone to do the work. The rest should have been thrown in the trash years ago. Set up something (or find someone that has already done so) and check each wheel hopefully before you buy them (or have the person agree to take them back). Check for both out of round and run out. Good luck.
Charlie Stephens
Old 11-28-2015, 05:51 PM   #17
1929
Charlie Stephens
I think you just convinced me to buy new ones Charlie, I was worried about the above.
Old 11-28-2015, 07:56 PM   #18
Tim B.
I stumbled upon Rally America's web site when I was looking for sources for wires for my 29. I didn't use them but they have an interesting web site. They are manufacturers of wire wheels and also refurbish and custom widen original equipment wires. Someone may have some feed back on them. Here's a link if you want to check them out. Tim
http://www.rallyamerica.com/Wire_Wheels.html
Tim B. is offline   Reply With Quote
Old 11-28-2015, 07:59 PM   #19
Charlie Stephens
Charlie Stephens
It was definitely not my intention to convince you to buy new ones, just to be careful. I don't know about anything current looking like they belong on a Model A. I would much rather trust an old one than a new one. With the cost of the new ones you should have no problem finding good '35 Ford or Kelsey wheels and end up with change in your pocket.
Charlie Stephens
Old 11-28-2015, 08:18 PM   #20
1929
those are nice looking wheels, but I don't think they fit on the A because of the drums.
