Old 11-24-2015, 11:24 AM   #1
petew
petew's Avatar
Default Rear End Gears
A friend of mine recently purchased a Model A complete rear end. It had been sitting outside for years but was intact.
He stripped it down far enough to count the ring and pinion and came up with a 9 tooth pinion and a 41 tooth ring gear. My math puts that at a 4.55 gear set !
He knows Model A's and swears that this is not an AA rear . He had been hoping to get himself a 3.78 or 4.11 ring and pinion but instead has 4.55's .
I could not find any info that shows Ford ever made gears that steep for a Model A. He has not removed the gears from the housing yet so he has no idea if there is a Ford stamping on them .
So my question for the experts is did Ford offer a 4.55 rear or do you think he has aftermarket gears there ?
Pete
petew is offline   Reply With Quote
Old 11-24-2015, 11:33 AM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Rear End Gears
I don't think that gear ratio was ever offered in a Model A style gear set.
I bet he mis-counted somehow.
Is he looking thru the drain or fill plug holes?
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 11-24-2015, 12:16 PM   #3
Jim Brierley
Companies used to make special gears for racing, etc. Getz was the most common.
Old 11-24-2015, 12:49 PM   #4
petew
petew's Avatar
Yes he counted properly , he had one of the axle tubes off and he chalked each component before counting. In fact he counted several times in disbelief !
Oh well I guess he will need to find someone who wants to swap a set of 3.78's for those Rockey Mountain gears !
Jim , thanks for the tip on Getz .
Pete
Old 11-24-2015, 12:54 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Some V8 60's & like a factory 4 cyl, in a '40 Pickup, used 4.44-1 gears. They were sought after gears, for Drag Racing.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 11-24-2015, 01:26 PM   #6
Fred A
Fred A's Avatar
Have used 4.55 gears with BW overdrives. Found new ones at Speedway. Model A based race cars would use them. Not rare but notable. It's about numbers which can cause those arithmeticly challenged to "assume". Good luck: Fred A.
Fred A is offline   Reply With Quote
Old 11-24-2015, 07:53 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Studebakers, like my 1950 Champion, used 4.56 gears with the BW overdrive.
Old 11-24-2015, 08:11 PM   #8
Rowdy
Vince, didn't Ford offer 3.54 gears as an option in coupes in 1929? Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 11-24-2015, 09:06 PM   #9
Rowdy
Ok, then what is with the speedo drive cap in section 4 of the JS? Note under the cap reads "Late 28 thru early 29, 40A only, 3.54:1." Just curious where the info for that came from. Keep in mind it is the 1997 version of the JS as I have not bought the updated version. Rod
Old 11-24-2015, 11:41 PM   #10
Fred A
Fred A's Avatar
Of the 41/9 gears that I have, one set i picked up at the LB T meet is by Republic. The other was bought new directly from Speedy Bill when it was rumored that he bought Getz. Asked about something lower than 4.11 and Bill made it sound like the price was a couple of hundred. When the new gears arrived the total was $300. Still needed them as the V8-60 produces more RPM than torque and they are a must in topgear with overdrive. 60s have gone from scrap to something more and sold the '40 engine before finishing the project. Again it is about the numbers(ratios). Good Luck: Fred A
