Old 11-19-2015, 09:18 AM   #1
Tacoma Bob
Tacoma Bob's Avatar
Default Shop lighting
Did a search and came up empty handed. I want to convert my 4 foot florescent tubes in my shop to LED. My current fixtures are all mounted and hardwired so I'm looking for a retrofit kit to eliminate the ballast and the "tombstone" pin holders. Any brand names and part number appreciated. TIA...TB
Tacoma Bob is offline   Reply With Quote
Old 11-19-2015, 09:34 AM   #2
burner31
burner31's Avatar
Default Re: Shop lighting
LED shop lights?
Now that's a good idea
Keith
Shawnee OK
'31 SW 160-B
Old 11-19-2015, 09:36 AM   #3
Larry Jenkins
Costco has a package of two self-contained LED lights that are absolutely marvelous!
Don't know much more, as I threw away the box. Was just amazed at how much brighter they are. About $70 on sale.
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 11-19-2015, 09:41 AM   #4
burner31
burner31's Avatar
Ebay-Jackscoolstuff $55
Why am I just learning about these?
Found them easy, $55 up to $100+
Keith
Shawnee OK
'31 SW 160-B
Old 11-19-2015, 09:47 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
Bob, Check out The Ford Barn's sister publication The Garage Journal http://www.garagejournal.com They have a whole Forum on "lighting".
Old 11-19-2015, 11:04 AM   #6
CarlG
CarlG's Avatar
Can't quite justify LED lights in my garage. Right before LEDs came out, I had completely re-done all the (mostly non-existent) lighting in my garage with new fluorescent lighting.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-19-2015, 11:15 AM   #7
Bob C
I got the ones from Costco. Just replace your old tubes with the new LED ones,
use your existing fixture.
Bob
Old 11-19-2015, 11:35 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
Bob
So then the old ballast must still be in the circuit........right?
I wonder how efficient this is compared to new LED's?
Old 11-19-2015, 11:44 AM   #9
CarlG
CarlG's Avatar
Of course, right now I have 16 fixtures in my house & garage that all use the same tube, and have a whole box of replacement tubes in stock. It's going to be a while before any of these get replaced.
Alaskan A's
Old 11-19-2015, 12:08 PM   #10
Wello
Wello's Avatar
I'm considering these:
http://www.amazon.com/Hyperikon®-Dua...cement+for+T-8
Wello is offline   Reply With Quote
Old 11-19-2015, 12:18 PM   #11
DougT
I just bought a bunch of 4 ft LED lights to replace the fluorescents in my shop that had bad ballasts. I got them at Menards for $35.00 each. They are the complete fixture with plug in ends. I bought one last winter and couldn't believe the difference. I think they are 3300 lumens at 41 watts each. They are quick to start down to 20F below. The brand name was Smart Electrician.
DougT is offline   Reply With Quote
Old 11-19-2015, 12:22 PM   #12
Charlie Stephens
If you are starting with incandescent lights going to LED's to save electricity it is definitely the thing to do assuming you use the lights on a regular basis. I didn't upgrade the lights in my attic because I seldom go up there. If you are starting with fluorescents and going to LED's the savings is much less. In my case I was going through a lot of fluorescent bulbs (probably due to bad electronics in the fixtures) and just replaced everything with LED's. At the time it was about the same price to replace the fluorescent fixtures as to upgrade them. I bought mine at COSTCO.
Charlie Stephens
Old 11-19-2015, 12:28 PM   #13
Doug in NJ
Doug in NJ's Avatar
I saw some of those LED retrofit "fluorescent" tubes at Home Depot. The light looked nice, but I noticed that the lumen rating was about 30% less than the T8 bulbs that they replaced. So do a bit of research before dropping a lot of money on replacements.
My garage has a pair of 8-foot fixtures each with two T12HO bulbs. These are pretty bright, and a couple of years ago I did a very worthwhile upgrade: I replaced the original magnetic ballasts with electronic ballasts (GE brand from HD, very reasonably priced). Now the lights start instantly even in the coldest weather, and there is no humming or flickering, and the ballasts do not get as warm as the old ones, so they are definitely more efficient.
One more thing on LED bulbs: If you house has those ceiling "can" lights, you really ought to install the Cree brand LED fixtures (sold by HD) in them. I've installed at least 30 of those around my house, and in two years I have had ZERO failures. They are easy to install, have good light, and are pretty inexpensive. They totally blow away the annoying CF bulbs that the fixtures used to have.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 11-19-2015, 01:09 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
Check here;
https://www.earthled.com/collections...lamps-with-led
Old 11-19-2015, 02:04 PM   #15
Bill's Auto Works
Bill's Auto Works's Avatar
While I was @ SEMA a few weeks ago, I looked at some very nice LED lighting called "Big Ass Lights" I am not sure if they do retrofits but their lights looked to be very high quality!
Your QUALITY Ford Barn Transporter- Open or Enclosed.
Bill's Auto Works Est. 1983 & Still Going Strong!
1955 Chevy Altered W.B. Gasser
1955 Nash Amb. Cust. Lemans
1964 Pontiac Grand Prix 2 DR HT
1966 Pontiac Catalina Conv
1966 AMC Ambassador DPL 2 DR HT
1966 AMC Ambassador Cust 2DR HT
1967 AMC Marlin
1967 Toronado
1973 Chevy Nova Full Chassis Car
1992 Jag XJS Conv
1992 Jag XJS 2 DR Coupe
2007 Cadillac XLR-V Supercharged Roadster
2008 Southern Customs Avalanche
Bill's Auto Works is offline   Reply With Quote
Old 11-19-2015, 02:12 PM   #16
holdover
When I built my dream garage I used CFL lights, I liked the idea of getting 100 watt equiv for only 25 watts. I have no regrets, there are 20 in my 40 X 60, set up in zones so I can light up just the area that I am working on. 7 years and all still work
holdover is offline   Reply With Quote
Old 11-19-2015, 03:22 PM   #17
Larry Jenkins
A clarification. The lights I got from Costco are two separate, 48" 2 LED bulb fixtures.
You just unplug the old one and plug these in. The two LED Bulbs are intregal to the fixture.
What is most amazing in the amount of nice, white light these put out. 3200 Lumens, 4000 Kelvin.. I think.
Larry
Old 11-19-2015, 03:45 PM   #18
Bill's Auto Works
The term retrofit is kind of a misnomer. All you do is buy the proper LED bulb that will fit your fixture, then remove the ballast & starter, then wire directly to the ends.
I would like to thank the O.P. for this post, I had been wanting to start upgrading my shop to LED's for a while & this post gave me the kick in the pants to do it. I just ordered a 10 pack of 8ft 48watt 240 led 6500 lumen bright white bulbs for $289.00 from a company on ebay. Unfortunately this is only about a quarter of what I need!
1967 AMC Marlin
1967 Toronado
1992 Jag XJS Conv
Old 11-19-2015, 03:54 PM   #19
CarlG
CarlG's Avatar
Originally Posted by Bill's Auto Works View Post
... I just ordered a 10 pack of 8ft 48watt 240 led 6500 lumen bright white bulbs for $289.00 from a company on ebay. Unfortunately this is only about a quarter of what I need!
Ka-ching !
Alaskan A's
Old 11-19-2015, 03:57 PM   #20
Tom Wesenberg
Not to worry Bill, the price will drop right after you buy them.
