Old 10-18-2015, 08:45 AM   #1
Bonniewwyn
Default HELP ! Need to Identify these Parts
A few years ago I purchased a Merc engine in pieces and these all came along with it. Supposed to be one assembly that will allow use of a T 5 trans behind that '51 Merc block. Also have clutches, flywheels and a 3 speed tranny. What do I have here ??
Bonniewwyn is offline   Reply With Quote
Old 10-18-2015, 12:27 PM   #2
Mart
Mart's Avatar
Default Re: HELP ! Need to Identify these Parts
The alumium plate and the flattish hogshead in the front of the 2nd pic go together to mount a T5 tranny to an early engine with the short bellhousing. It is normally used with a truck adaptor which converts the 8BA (Merc) type block to the early type bellhousing. It may be possible to use one of the bellhousings shown (with the matching starter plate) to achieve the same conversion. I believe some of this forum have done this. (Ron??)
If one of the later bells is steel, then it is easier to convert, as you can weld to it.
No personal experience of doing the above conversion, just what I've picked up following such items in here and the hamb.
Mart.
