Old 05-09-2014, 07:01 PM   #1
38 coupe
38 coupe's Avatar
Default 37 or 38-39 fender skirts
I just got a set of 37 or 38-39 fender skirts with no hardware on them. They were advertised as 37 skirts. I have read on this site that the 37 skirts are longer than the 38-39 skirts. Can someone give me measurements on 37 skirts and on 38-39 skirts? I'd like to know what I have. I plan on using them to replace the after market skirts on my 38 coupe.
Thanks!
Old 05-09-2014, 07:07 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: 37 or 38-39 fender skirts
Can you post a picture of the skirts? That would make them easier to identify.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 05-09-2014, 08:02 PM   #3
swoopNZ
MEMBER EMERITUS
Try them against your 38 coupe rear fenders.
if they are '37 they will be about an inch or so wider each side at the bottom.
38-39 will fit straight into your fender.
This applies to original skirts only.
You can get the rubber seals from Dennis Carpenter.
Regards,
Chris.NZ.
New Zealand.
swoopNZ is offline   Reply With Quote
Old 05-09-2014, 11:40 PM   #4
38 coupe
38 coupe's Avatar
Here are pictures of the skirts.
Old 05-11-2014, 12:24 AM   #5
fordlovr
fordlovr's Avatar
Hi yours look the same as mine which fit my 1938 Deluxe. 17'' from top to bottom and 29 1/2 '' from the pointy bit to pointy bit !!! along the bottom,not including the curly brackets. Excuse my technical lingo ! hope this helps. BJ
fordlovr is offline   Reply With Quote
Old 05-11-2014, 12:57 PM   #6
38 coupe
38 coupe's Avatar
fordlovr, thank you! Technical lingo understood. This is exactly the information I was looking for.
Old 05-12-2014, 07:50 AM   #7
38 coupe
38 coupe's Avatar
Out of curiosity, does anyone have these measurements for 37 skirts?
Old 05-24-2014, 08:54 AM   #8
38 coupe
38 coupe's Avatar
Originally Posted by fordlovr View Post
17'' from top to bottom and 29 1/2 '' from the pointy bit to pointy bit !!! along the bottom,not including the curly brackets. BJ
I am now a bit confused. Yesterday I finally got to see my skirts. I held them up to my 38 coupe and they looked like they fit the fender opening. I held them up to my 37 sedan and they looked smaller than the fender opening. I happily concluded I had 38-39 skirts. I then measured them just like fordlovr measured his. My measurements are 31 inches from pointy bit to pointy bit and 18 inches top to bottom.
Do I actually have 37 skirts? How do these fit into the fender opening? Will these fit my 38 coupe, or did I get a set of skirts for my dad's 37 tudor flatback? I didn't install mine since the skirts need work, the latch part is missing, and have no gasket to protect the fender paint.
Any wisdom and clarification is appreciated!
Old 05-24-2014, 07:44 PM   #9
johnny
Thereis a person on e pay that sells the nuts should you need them Johnny
johnny is offline   Reply With Quote
Old 05-25-2014, 05:10 AM   #10
swoopNZ
MEMBER EMERITUS
The gasket is actually a rubber seal.
Dennis Carpenter sells them.
$30/pair.
Old 08-24-2015, 09:59 PM   #11
38 coupe
38 coupe's Avatar
Update: The fender skirts that I have are 37 skirts. The flange on the back of the skirts is larger in diameter than the wheel opening on 38-39 (and 40) rear fenders. The flange is the same size as the wheel opening on 37 rear fenders.
So, for correct Ford fender skirts:
31 inches "pointy bit to pointy bit" by 18 inches tall = 37 fender skirts
29 1/2 inches "pointy bit to pointy bit" by 17 inches tall = 38-39 fender skirts.
To confuse the issue a bit I recently purchased what I was told are very early after-market fender skirts. From the outside they sure look like Ford skirts. The back looks a bit different. The really interesting thing is they are the same size as 37 skirts, but the back is smaller, so the skirts fit 38-39 fenders. Here is a comparison of the skirts:
One of the after-market skirts in front of a 37 skirt. They are the same size:
The flange on the back of the 37 skirt is right out at the edge of the skirt. This matches the configuration of the 38-39 skirt that fordlovr posted the picture of:
The back of the after-market skirt looks very different. The flange area is a series of straight sections, and they are nowhere near the edge of the skirt:
The after-market skirts look good though, so I will eventually run them on my 38 coupe.
Old 08-25-2015, 06:49 AM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
I have a set of similar looking skirts (aka spats, or wheel covers ) that were on a '35 coupe. Are these possibly '37-'39 as well? These have a hex shaped attaching device at top and key operated locks on both sides at bottom. I need to carefully look these over for some type of manufacturers identification.
John
Old 08-25-2015, 02:33 PM   #13
johndee138
johndee138's Avatar
I "NEED" a set like these for my car. Any one have a line on a pair for a 36?
johndee138 is offline   Reply With Quote
Old 08-25-2015, 03:02 PM   #14
39topless
The wheels and hubcaps are one of the most beautiful aspects of these early V8's. So why cover half of them up?
Phil
39topless is offline   Reply With Quote
Old 08-25-2015, 03:17 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
Phil
If the one below doesn't answer that question for ya, you'll never understand! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-25-2015, 03:28 PM   #16
petehoovie
petehoovie's Avatar
I'm pleased that I will never understand.....
Old 08-25-2015, 04:40 PM   #17
fordscript
fordscript's Avatar
Wow, that 34 just took my breath away!!
fordscript is offline   Reply With Quote
Old 08-25-2015, 05:16 PM   #18
39topless
Ditto!
Old 08-25-2015, 05:40 PM   #19
Fe26
Originally Posted by v8coopman View Post
if the one below doesn't answer that question for ya, you'll never understand! Dd
sweet!
Fe26 is offline   Reply With Quote
Old 08-27-2015, 07:27 PM   #20
38 coupe
38 coupe's Avatar
Your skirts look like after market skirts in the shape of 37-39 skirts. Use the measurements in my earlier post to determine which year it fits. It appears the bolt was added for looks and doesn't operate any fasteners on the skirts. I think the key locks may have been added after purchase as well.
These folks can supply you. I almost bought a set from them before I found the black pair shown above:www.agapeautoparts.com, http://photos.agapeautoparts.com/Gal...t=Photo&ci=008
