Old 08-15-2015, 09:21 PM   #1
RalphG
RalphG's Avatar
Default Mercury Water Pumps again
Just an update. I decided to keep both rebuilt pumps, even the left side one with the wrong pulley since I read here that it can work just buy a different length belt to run both pumps off one belt.
Got the left side pump off this evening and my worst fears did not happen. The internal bolt in the lower water outlet was pretty stubborn but came out without rounding off the head or twisting off. I had to use a 14 mm socket as the nine sixteenths seemed a loose fit and I was afraid it would round off. Lots of penetrating oil and patience.
RalphG is offline   Reply With Quote
Old 08-15-2015, 09:40 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Mercury Water Pumps again
That bolt location was not one of Henry's better ideas.
Old 08-15-2015, 11:22 PM   #3
fordlovr
fordlovr's Avatar
I Use'd a stud, brass nut and some silastic type goo on the end of the stud. I did this 4/5 years ago, havn't had a pump off since, but will be interesting to see if it helps any!
fordlovr is offline   Reply With Quote
Old 08-15-2015, 11:45 PM   #4
RalphG
RalphG's Avatar
I was thinking maybe some anti-sieze applied to the threads on installation would be a good plan.
On another related note, what was the idea of having each water pump driven by a separate belt?
Old 08-15-2015, 11:53 PM   #5
Graeme / New Zealand
Graeme / New Zealand's Avatar
Stainless bolt with anti-seize is what I used.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 08-16-2015, 08:10 AM   #6
big deuce
big deuce's Avatar
You could heat the head of the bolt up till its red, and let it cool on its own. It will shrink a bit after it cools, and the expansion/contraction breaks the rust loose.
big deuce is offline   Reply With Quote
Old 08-16-2015, 08:44 AM   #7
4t8v8
GB
Did the same thing on mine except didn't use anti- seize when I rebuilt it 25 years ago. Recently rebuilt both pumps. Bolts came out easy.
4t8v8 is offline   Reply With Quote
Old 08-16-2015, 09:22 AM   #8
38 coupe
38 coupe's Avatar
Having a separate forward belt on the passenger side moves the belt further from the distributor. It makes it safer to adjust the timing while the engine is running.
Old 08-16-2015, 10:09 AM   #9
RalphG
RalphG's Avatar
Interesting. I had never considered that but it makes sense. I suppose the other option would be to remove the belt while adjusting timing.
Old 08-16-2015, 10:29 AM   #10
V8 Bob
V8 Bob's Avatar
The narrow 3/8" belt is a bit farther away from the distributor, but I'll bet the reason was more about cost; cast 1 piece narrow crank pulley vs the larger multi-piece sheet metal wide belt pulley and 3/8" vs 5/8" belts, also possibly wanting to slow the fan by using the smaller/outer narrow belt crank pulley.
Old 08-16-2015, 01:26 PM   #11
RalphG
RalphG's Avatar
And speaking of pulleys, I just noticed that the new pulley is an inch smaller diameter than the original offset pulley. Have not compared the right side but I would assume it is also smaller than the original. I hope this won't be a problem. Currently I am having great difficulty lining up and starting the two mounting bolts. Pump bolts are all started and loose, prying the engine around with a pry bar but so far no luck starting a thread on those two bottom bolts.
Old 08-16-2015, 02:02 PM   #12
V8 Bob
V8 Bob's Avatar
JFYI, the outside diameter of the '50-'53 Ford/Merc driver's side narrow belt pulley is +/- 4.1", while the passenger side is +/- 4 3/4". The larger diameter crank pulley drives the larger ds pump pulley, and the smaller crank drives the smaller ps pump, so both pumps will run the same rpm.
Old 08-16-2015, 02:23 PM   #13
RalphG
RalphG's Avatar
Yes, my rough measurement on the new pulley was 4 inches. So now running both pumps off the same crank pulley I should be ok.
Old 08-16-2015, 08:25 PM   #14
supereal
supereal's Avatar
Most good hardware stores stock stainless steel bolts that will replace the originals in the pump inlet. You may not need them, but the next guy will thank you.
supereal is offline   Reply With Quote
Old 08-17-2015, 03:49 AM   #15
When I took my pumps off one of the mild steel bolts inside was "shagged" to the point it was rounded off and my regular socket set could not get a grip on it. I brought one of those Urwin socket sets that have the grippy bity things inside, then it came out real easy.
GB
Old 08-17-2015, 08:49 AM   #16
RalphG
RalphG's Avatar
GB
I have heard of those type sockets and was hoping I would not need one. Lucky these pumps had only been on the engine since the early eighties. Even so there was a little corrosion on the bolt heads which is why I needed to use a 14 mm socket giving a tighter fit than 9/16.
Latest discovery: the right side motor mount is loose on the cross member. Hoping it just needs tightening.
Also discovered the car serial number is stamped into the top of the frame near the right side water pump.
Old 08-17-2015, 10:27 AM   #17
rotorwrench
rotorwrench's Avatar
I have a press and a good puller to rebuild pumps. It took a while to make several pusher tools & pressing adapters but it was worth the effort. You can press the sheave of of the old pump and likewise for the rebuilt and swap them out to get an original arrangement. Just be carefull with the cast type pulley sheaves. They break easily.
Old 08-17-2015, 10:34 AM   #18
JAKEFORD
I bought a "Gator Grip" socket a few years ago for a similar problem and it worked very well.
Amazon.com has them listed.
JAKEFORD is offline   Reply With Quote
