Old 08-12-2015, 06:47 PM   #1
wbs
Default hand crank, not sure if model A
hello- ibought used crank but now not sure if it's for model A-does not lock in crank nut well and slips out easily. the pins are oval-should they be round? i';ve enclosed a picure attachment---i put tape on the pin to better show the shape of the pins. is this model A crank? thanks
wbs is offline   Reply With Quote
Old 08-12-2015, 07:37 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: hand crank, not sure if model A
"Maybe" it fits an OVALMOBILE??
"THE ASSISTANT GURU OF STUFF"
Old 08-12-2015, 07:42 PM   #3
Bob C
How about a picture of the whole crank??
Bob
Old 08-12-2015, 07:53 PM   #4
wbs
silly answer from Bill-williamson-----
Old 08-12-2015, 08:12 PM   #5
Rowdy
Measurements with the pic's of the whole crank would be a game changer in determining if it is Model A or not. Many originals have alot of wear on the lugs. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 08-13-2015, 02:31 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Also check the 4 teeth on the ratchet bolt that the crank engages. Many of them have been used a lot and have been so badly worn they don't hold the crank lugs too well.
Old 08-13-2015, 11:06 AM   #7
wbs
thank you -will check teeth-also took measurements and found the diam of crank is .75" the pin is 3/16" thickness and is 3/8 " in breadth-------i don't think it was a round pin that has ovalled out.
i guess the last ques i have is: is the crank pin to a model A round, if so this is not a model A crank. thank you
Old 08-13-2015, 03:16 PM   #8
Tom Wesenberg
My original crank pins are oval.
Old 08-13-2015, 04:08 PM   #9
BILL WILLIAMSON
My crank pins will always be PERFECT. I'm such a WOOSE, that I CAIN'T crank it. Hope no one gives me a "T" Model Chief sed, "T"= TROUBLE"!!
Bill W.
Old 08-13-2015, 10:51 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Old 08-14-2015, 12:14 PM   #11
wbs
Thank you all I am most thankful I did not know that cranks had so many variations. Thank you especially for the list of cranks, I had no idea
Old 08-14-2015, 02:18 PM   #12
johnmi
Mike would you please explain to me what lugs (1) stands for and throw (2) means. Thanks John
johnmi is offline   Reply With Quote
Old 08-14-2015, 02:36 PM   #13
Bob C
Look at the chart near the bottom for the answer.
Bob
