Old 08-07-2015, 05:19 PM   #1
Ed Saniewski
Ed Saniewski's Avatar
Default Transmission Tower leaks
A friend of mine is complaining about oil leaking out of the top of his transmission tower. He asked me if there is a seal in the tower and I told him not that I know of. He has a rubber boot that covers the top of the tower and vent hole, and that is where the oil is coming from. He runs with mostly Lucas oil, but I think he also has some 600 in there too. Is that too thin and causing the oil to splash out? I have Philips Conaco 680 oil that I use in my trans and rears, Wouldn't that better for him?
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
https://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 08-07-2015, 05:25 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Transmission Tower leaks
"Maybe" his concoction is FOAMING?? or grossly overfull??
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-07-2015, 05:29 PM   #3
redmodelt
redmodelt's Avatar
"Lucas oil" does not tell us anything. Lucas like almost every other oil, it comes in different viscosity's and weights.
Yes 600W or similar lube would be better, just guessing because without knowing what he has in it now... There are no seals and the vent hole needs to be open.
At this point I would suggest; drain, flush and refill with the proper lube to the correct level.
Old 08-07-2015, 05:52 PM   #4
BILL WILLIAMSON
HEY, Rufusmodelt Guy,
Remember awhile back, a poster had the same complaint? He filled it to the TOP of the case, before he put the tower on.
Bill W.
Old 08-07-2015, 06:32 PM   #5
Tom Endy
Tom Endy's Avatar
Look to see if the vent hole in the base of the tower is plugged. it is in the back right above the floor board. Push a wire through it to open it up if it is plugged.
Tom Endy
Old 08-07-2015, 07:31 PM   #6
JohnLaVoy
JohnLaVoy's Avatar
We wrote about this a few years ago. The "600W" trans fluid is not really suited for this application. It foams up at high rpm. We found 140W at 75% and 25% STP have you the viscosity of the 600W when Model As were new and the tackifier needed for use in straight cut gear applications.
JohnLaVoy is offline   Reply With Quote
Old 08-07-2015, 08:06 PM   #7
redmodelt
redmodelt's Avatar
Sorry but I know of a number of transmissions that have the 600w filled to the proper level and are just fine that are driven at normal Highway speeds.
Who is we and do you have a link to that discussion?
Bill must have missed his follow up and yes sorta. There are so many shooting lube out the top, side, back front it hard to keep track!
Old 08-07-2015, 10:14 PM   #8
BILL WILLIAMSON
Why not use a quality 140W in the trans & diff?
Bill W.
Old 08-08-2015, 06:38 AM   #9
Ed Saniewski
Bill, I use a 140W oil in the overdrive trans, but thought that would be too thin for the straight cut gears of the model A.
Tom ,we are in the process of cleaning out and rebuilding his trans after one of his roller bearings in the cluster gear came apart at the MARC meet in Niagara Falls.I will make sure the hole is cleaned out.
Old 08-08-2015, 07:39 AM   #10
Benson
Default Re: Transmission Tower leaks-bad Roller bearings damaged gears
I also had a roller bearing come apart in the cluster gear ... made the loudest noise in second gear that Steve Becker at Bert's had ever heard.
I had reused the roller bearings on a rebuild because " the rollers looked good and were not pitted".
What I did not notice was that the "pins" that secure the rollers in the cage were badly worn to the point that the pins were just "sharp points".
One roller had the holes in the cage "worn to twice the normal size".
When the bearing came apart it allowed the cluster gear to move up/down on the shaft.
This ruined a brand new Mark Cluster and second slider gear. The second gear mating surfaces were badly worn.
Note all gears were new when rebuilt.
Old 08-08-2015, 08:47 AM   #11
Mitch//pa
Reusing old trans bearings is like building an automatic and reusing the clutches / bands.
Everyone should be familiar with Tom Endys transmission prudence article which gives you a list of the common things to replace on a tear down.
Much of it is common sense
Old 08-08-2015, 08:50 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
The maximum oil level in the transmission is fixed by the height of the fill hole unless oil was added with the gearshift off.
Bob Bidonde
Old 08-08-2015, 08:59 AM   #13
Benson
Yes ... but 35 years ago when I did the rebuild there was no internet, or Ford Barn ....
Not even ASE.
Much of it then was common sense!
I know I should have been a "Know it all" but I was busy working 60 or 70 hours a week fixing IBM computers and dealing with thousands of bulletins and tech tips at 2 o'clock in the morning ...
Old 08-08-2015, 10:28 AM   #14
Benson
For the record I am going to come right out and say it:
1. I post my experiences like this one so that maybe some new folks can learn from them and not repeat the same mistake.
2. I do not do this so that I can be called stupid on this forum ...
I have many more things to post that I have learned in 53 years of "Model A-ing" that I have not posted and I will not do it anymore.
just saying ...
Old 08-08-2015, 12:21 PM   #15
BILL WILLIAMSON
When rebuilding a trans, parts list should begin with, ALL, BEARINGS, SEALS & GASKETS!!!
Bill W.
