Can someone give me a catalog # for the correct bulb?
I tried to guess and ordered some bulbs but they don't fit.... |
#51 I used to get them from NAPA.
Thank you, Terry but can you cross-reference it to Macs or Dennis Carpenter ##?
NAPA doesn't ship to Russia |
Mac's #13465K 6V, 1 Candle Power
Carpenter 48-15021-51 |
Terry, thanks a lot!
I finally got a lightbulb, it's too small ![]() any other suggestions? check the photos |
i might have a couple laying around, i went 12v. will check and if i still have them i can mail them to you for shipping cost. let me know if you still need them by email.
george s.dakota [email protected] |
You have the correct light bulb for the 39 hot water switch but there is a problem with your switch, it appears as if the plastic knob has come apart and the metal part of it is still in the switch. See if you can pull it straight out of the switch and the light bulb should fit properly, you should then be able to clean both the metal and the plastic and super glue the metal back into the knob. make sure the marking on the plastic aligns properly with the switch before the glue sets.
Terry, thanks for the photo - I will look into it thoroughly
Ok, I looked at the switch - the metal part (sleeve) in the middle is a part of the switch itself, it's attached inside to the round plate with contacts that rotates when you turn on the switch. And that metal sleeve has indents on the inside surface that are supposed to hold a bulb (at least I believe so).
Maybe it's not an original '39 switch? There are no numbers on it, just some words "Boston, Massachussets, patent pending". I'm stuck. |
