Old 06-23-2015, 10:02 AM   #1
f1builder
Default changing u joint-47 ford sedan
i have to change my u-joint on the 47 tudor and i haven't done this before. can someone give me kind of a step by step process? my mechanic isn't around for a while and i need to know if its something i can handle. thanks loads....george in south dakota.
f1builder is offline   Reply With Quote
Old 06-23-2015, 12:07 PM   #2
ford38v8
ford38v8's Avatar
Default Re: changing u joint-47 ford sedan
Front floormat & tranny cover out> Speedo cable disconnect> Frame up on four jack stands> Rear wheels off> Rear brakes, including parking cable off at torque tube> Rear shocks free> Clamshell off> Banjo up on floor jack> Spring mount disconnect> Roll driveline assembly out with floor jack 6" only> Remove U joint. Reverse the procedure and bleed the brakes.
First and foremost, What symptoms are you having that tell you you need to change your U joint?
Alan
Old 06-23-2015, 01:58 PM   #3
George/Maine
George/Maine's Avatar
I can see I have some work ahead of me.
I knocked a tooth out of 1 st gear on my 47 car trans change time.
George/Maine is offline   Reply With Quote
Old 06-23-2015, 02:52 PM   #4
f1builder
i don't know for sure but figured it was the ujoint. it is making an unusual noise especially when turning or starting out. it sounds like directly underneath the seat area. i will take it for a spin again and try to be more specific after i get done with my chores.
thanks a lot for the info.
george
Old 06-23-2015, 05:55 PM   #5
Steves46
Steves46's Avatar
If you haven't done so already you may want to shoot some grease in the u-joint and see if that helps.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 06-23-2015, 07:24 PM   #6
f1builder
i took it out for a spin this afternoon, drove about 20 miles and didn't hear the noise. will grease it up just to be sure. don't know what was going on, just the old ford syndrome i guess. plus i am trying to do my shake down cruise before i do a real road trip. thanks guys.....
Old 06-23-2015, 10:10 PM   #7
Old Henry
Old Henry's Avatar
Just in case you decide to replace the U-joint. Here are the detailed instructions for removing the rear axle which is what is necessary to replace the U-joint:
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 06-23-2015, 10:44 PM   #8
f1builder
thank you old henry.....this is great. problem is i can't print it out like it is formatted. can i trouble you to email it to me? [email protected]
thanks a bunch.
george
