Old 06-02-2015, 03:37 PM   #21
V12Bill
V12Bill's Avatar
Default Re: Wheel nut torque ?
Uneven tightening of lugs on disc brake rotors has been known to cause warping of the rotors. Could possible do the same to a drum to say nothing of loosing a wheel at speed for being too loose.
V12Bill is offline   Reply With Quote
Old 06-02-2015, 03:41 PM   #22
sidevalve8ba
sidevalve8ba's Avatar
Originally Posted by scooder View Post
Tight, but not red face tight.
Martin.
Best one I've heard yet.
sidevalve8ba is offline   Reply With Quote
Old 06-02-2015, 04:28 PM   #23
Mart
Mart's Avatar
Four white knuckles.
Old 06-02-2015, 06:28 PM   #24
48 coupe
48 coupe's Avatar
half turn before they twist off.
48 coupe is offline   Reply With Quote
Old 06-03-2015, 10:57 AM   #25
Bruce Lancaster
"1949-1951 Ford per shop manual- 65-75#"
Go with a Ford spec like this if using a torque wrench. Ford used the same nuts and threads from '29---up into the 1970's (Model A's had capped acorn nuts, which changes nothing, all otheres entirely identical) on big cars and pickups.
If not using a torque wrench, use something fairly short like the original wrench that came with car to tighten, and keep something long like a breaker bar to loosen. If you reverse that you will have some bad moments next flat...
Old 06-03-2015, 11:25 AM   #26
JSeery
JSeery's Avatar
Interesting thread, every nut/bolt/thread has a torque value but in most application they are never used! Wheel lug nuts would be one of them, I have never seen a lug nut set to torque value.
Old 06-03-2015, 11:46 AM   #27
Charlie Stephens
My local Costco does it. After tightening with an impact wrench they check it with a real torque wrench. Then they ask you to come back in 500 miles for a recheck. This, along with low price, is why I buy most of my tires there.
Charlie Stephens
Old 06-03-2015, 11:54 AM   #28
34PKUP
34PKUP's Avatar
Charlie Stephens
When is the last time you saw Costco do a 30's vintage Ford without aluminum wheels.
34PKUP is offline   Reply With Quote
Old 06-03-2015, 11:57 AM   #29
JSeery
JSeery's Avatar
It would be a good idea as how almost all of the tire places way over tighten lug nuts!
Old 06-03-2015, 12:01 PM   #30
51 MERC-CT
51 MERC-CT's Avatar
Yep' if Henry was worried about torque, with each car he would included a combination torque wrench, bumper jack handle, hub cap remover instead of the lug wrench, jack handle, hub cap remover.
Old 06-03-2015, 12:45 PM   #31
NealinCA
NealinCA's Avatar
I figure that I have to tighten all the lugnuts somehow. I have a click type torque wrench handy, so I always use it to tighten lugnuts...on all of my vehicles.
We had multiple people putting the wheels back on a pickup, one of the front wheels didn't get tightened and the hubcap was put back on. I drove the truck and ruined the front wheel. I just made it a habit to hear those 5 clicks on each wheel before I head down the road. Makes me sleep better at night...
Neal
NealinCA is offline   Reply With Quote
Old 06-03-2015, 03:41 PM   #32
V12Bill
V12Bill's Avatar
I once broke a 13/16" 1/2" drive socket using a 14" breaker bar to try to loosen a lug nut that a tire jockey had put on with an air wrench. Fortunately I was at home and not on the side of the road and got another socket and removed the rest of the lug nuts.
Old 06-04-2015, 07:24 AM   #33
jimalabam
jimalabam's Avatar
Great Comment Lawson...
jimalabam is offline   Reply With Quote
