Old 05-26-2015, 05:52 AM   #1
hb32
hb32's Avatar
Default 32-34 commercial exterior mirror
Looking for a source for a black steel mirror head for an original bracket. I have a picture of what it is supposed to look like but no luck. Seems like the suppliers only make a reasonable copy in chrome or stainless.
hb32 is offline   Reply With Quote
Old 05-26-2015, 06:47 AM   #2
32forddump
32forddump's Avatar
Default Re: 32-34 commercial exterior mirror
Can you show us the picture?
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/
32forddump is offline   Reply With Quote
Old 05-26-2015, 08:06 AM   #3
al's28/33
al's28/33's Avatar
Tough to find a clean original, but there are repros of the black steel types maybe not FORD but you can modify the bolt threads to fit through the arm bracket, that's what I did. found a 4" round mirror on that auction site and made it fit.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 05-26-2015, 08:39 AM   #4
hb32
hb32's Avatar
Here is what I have found.
Old 05-26-2015, 08:52 AM   #5
2935ford
2935ford's Avatar
Looks very much like what I have on mine.
2935ford is offline   Reply With Quote
Old 05-26-2015, 11:21 AM   #6
Mike51Merc
Mike51Merc's Avatar
What is the diameter of mirror? I have some mirrors I could measure for you. Not OEM Ford, but replacement heads. Some in original boxes.
Mike51Merc is offline   Reply With Quote
Old 05-26-2015, 12:02 PM   #7
DavidG
DavidG's Avatar
The one you have is pretty close to original, except the threaded stud is longer and it had three small round head screws on the back of the mirror head close to the stud to permit adjustment of the tension. Unfortunately, I screwed up my photo files and I can't send you a photo of an original. (If you have the V-8 Club '32 book, it is shown on page 16-9.)
Old 05-26-2015, 12:51 PM   #8
Bruce Lancaster
Bratto's shows this 3-screw 5 1/2" mirror in black for late A pickup...
http://www.brattons.com/uploads/imag...arge/24270.jpg
Is it similar or the same? Parts book shows the B82 type assembly replacing an A equivalent, but lacks a number for just the mirror head.
Old 05-26-2015, 03:23 PM   #9
DavidG
DavidG's Avatar
Perhaps as close as you'll get. About the only remaining difference is the recessed area on the back around the perimeter. The original was tapered right to the edge without a recessed area.
Old 05-26-2015, 03:32 PM   #10
hb32
hb32's Avatar
Thanks for all the insight.
I don`t need it to be exact but close.
I was of the understanding that it was suppose to be 4" in diameter but the Brattons version is 5 "
Can you measure yours 2935 ?
Old 07-13-2015, 04:48 PM   #11
hb32
hb32's Avatar
Still looking
Old 08-28-2015, 12:50 PM   #12
hb32
hb32's Avatar
Bttt
Old 10-08-2015, 03:42 PM   #13
hb32
hb32's Avatar
Bttt
Old 10-08-2015, 09:19 PM   #14
totto
totto's Avatar
hb32: what you show is very similar to what I have and mine has the 3 screws. Found/got mine from Dennis Carpenter @ Early Ford V8 meet in Dearborn a few years back. If you find a black one with screws, then your set; some newer(post WWII-early '50's) ones have phillips screws and just change screws to slotted.
totto is offline   Reply With Quote
