Old 04-12-2015, 10:31 AM   #1
1929
Default rear axle carrier assembly
does anyone have a picture of a normal rear axle carrier assembly
1929 is offline   Reply With Quote
Old 04-12-2015, 10:49 AM   #2
Bob C
Default Re: rear axle carrier assembly
Check out Tom Endy's article. http://www.santaanitaas.org/wp-conte...vised-2014.pdf
Bob
Old 04-12-2015, 11:17 AM   #3
1929
Originally Posted by Bob C View Post
thank
Old 04-12-2015, 12:06 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Here's a few pictures of a rear end I picked up a week ago. I got the complete rear end except the bolts for the axle tubes. Everything looks good except one keyway. I should probably sell it instead of storing it for spare parts.
Old 04-12-2015, 08:58 PM   #5
1929
wow, i thought my keyway was bad, mine are widened out, Iam gonna have to buy new ones or used.
Old 04-12-2015, 09:36 PM   #6
RUNNERBUN
RUNNERBUN's Avatar
Not wishing to hijack the threasd, but is there a correct direction for the 9 bolts that hold the carrier together. Bolt head or nuts on the crown wheel side. I have seen them fitted both ways.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 04-12-2015, 10:15 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
I have a keyway just like that one.
Old 04-12-2015, 10:42 PM   #8
Tom Endy
Tom Endy's Avatar
The early carriers with the half-dome bolt heads faced in one direction, the later carriers with rectangular shaped bolt heads faced in the opposite direction.
The early carriers had the nuts on the flat surface of the ring gear, the later carriers had the head of the bolt on flat surface of the ring gear.
The early carriers had flat mating surfaces on the two carrier halves. The later carriers had notched mating surfaces.
The early and late carrier assemblies do not have interchangeable parts, except for the nine hex nuts.
There are photos and a description of the early and late carriers in the link posted above.
Tom Endy
Old 04-12-2015, 10:57 PM   #9
RUNNERBUN
RUNNERBUN's Avatar
Tom Endy
Many thanks for the explanation Tom
