Old 04-08-2015, 08:06 AM   #1
ldj1002
Default Linkage on carb.
1950 V8 RTH engine. I have taken the carb. apart but can't get the little short linkage to the accelerator pump off, therefore I can't remove the pump. How do I get it off?
ldj1002 is offline   Reply With Quote
Old 04-08-2015, 08:40 AM   #2
Charlie ny
Default Re: Linkage on carb.
002,
Some links have a spring clip on the thru end...not always real visible
unless you know it's there. If no clip just try winding the link back and forth
to work the tiny retaining ball ( which you cannot ever see ) loose. This is a
common "joy".
Charlie ny
Old 04-08-2015, 10:02 AM   #3
ldj1002
I can see the ball but it won't come out. Afraid I'll brake it
Old 04-08-2015, 10:29 AM   #4
scicala
scicala's Avatar
I don't think you can possibly see the spring loaded retaining ball with the pump link still installed, since it is inside of the hole in the pump rod. You must be looking at the tip of the pump link that goes through the pump rod.
Try using the tip of a screw driver to pop the link out from the back side. A little oil may help too.
Sal
scicala is offline   Reply With Quote
Old 04-08-2015, 12:29 PM   #5
tubman
tubman's Avatar
I always hit the area around the ball at the top of the link with a penetrant a couple of days before I begin on the carb.
Old 04-08-2015, 06:42 PM   #6
ldj1002
OK, I guess I don't understand. The rod that goes up through the carb body that the linkage connects to has 3 holes in it. One on the bottom and the linkage sticks through 1 side and pokes out a little on the other side. I have cleaned the carb body good as well as put PB Blaster all on and around where the linkage goes through. I have used screwdriver and tried to pry it out, no luck. The linkage is loose in there, I can wiggle and turn it. What holds it in? If some kind of a socket and spring is in there, how did they make it, I see on evidence of it coming apart.
Old 04-08-2015, 06:49 PM   #7
JSeery
JSeery's Avatar
Might try a photo.
Old 04-08-2015, 07:43 PM   #8
ldj1002
Originally Posted by JSeery View Post
Might try a photo.
Good idea, Here is a photo
Old 04-08-2015, 07:46 PM   #9
JSeery
JSeery's Avatar
Now that is a detailed photo!
Old 04-09-2015, 10:15 AM   #10
scicala
scicala's Avatar
Twist and pull it while applying pressure with the tip of a screw driver on the back side. There is a spring loaded ball in the hole where the pin goes through that seats in a groove in the pin.
Sal
Old 04-09-2015, 12:19 PM   #11
flatjack9
flatjack9's Avatar
I had one that would not let go. Finally cut the pump rod and removed both ends. Installed new parts. Sometimes that's about all you can do.
Old 04-09-2015, 02:22 PM   #12
tubman
tubman's Avatar
Get a pair of the right sized needle-nose pliers, grab the large part of the shaft as tight as you can with the pliers as far in as you can, and then grab a piece of 2X4 or something similar and give the pliers a good swat on the end of the handles. (Try to hit the end of the handles evenly and watch out for your fingers!)
Old 04-09-2015, 08:58 PM   #13
ldj1002
Got it out. Someone sent a PM to use a punch or nail and drive it out from back side. It worked.
