Old 03-24-2015, 07:53 PM   #1
glenn in camino
glenn in camino's Avatar
Default B block cracked
I have a B block that's cracked under one or two of the insert valve seats. Is there a permanent fix for this problem, or should I just get a boat and chain. I believe there's usually a fix for everything.
Old 03-24-2015, 08:20 PM   #2
mshmodela
mshmodela's Avatar
Default Re: B block cracked
I recall seeing a video that I believe cracks around the valve seats is one of the worst areas for cracks. I'd wait to hear from an engine rebuild pro for sure....
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 03-24-2015, 08:24 PM   #3
Synchro909
Synchro909's Avatar
B engines are notorious for cracking in that area and it is made worse by putting valve inserts in. I NEVER put them in either an A or B engine. They are simply not needed and lead to the early demise of the block. Bad move, this was always going to happen once the inserts were put in.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-24-2015, 09:22 PM   #4
Pete
It CAN be welded. Don't junk it.
Old 03-24-2015, 10:42 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
They can be "stitched". There was a post here a short while ago I believe that showed the repairs to an A block if several places. Was it from J&M in Mass?
I found it!!
https://www.fordbarn.com/forum/showpo...8&postcount=17
Old 03-25-2015, 01:43 AM   #6
hardtimes
hardtimes's Avatar
Hey glenn,
Yes, that type crack in those type areas can be fixed. Finding the right person with the right skills is the hardest part.
And, IMO, and experience, hardened valve seats can and should be put right back in after proper fix is made. Helps to prevent recurrence of cracks.
Old 03-25-2015, 02:39 AM   #7
colin1928
colin1928's Avatar
Hi Glenn
Cracks under the seat insert can be repaired but IMO these are among the hardest to repair inserts are a interference fit and if fitted to tight the repair can reopen to loose and the insert comes loose
BTW which way does the crack travel down into the port or up into the deck as that would change how you might go about the repair
Do not junk it and let us how you get on with it
Colin
colin1928 is offline   Reply With Quote
Old 03-25-2015, 08:20 AM   #8
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
The only way this block would be a boat anchor is If you take it to the wrong machine shop and they weld it.
I have posted this picture a few times in the forum but it's worth reposting to save a valuable block.
It's a common occurence on Model A/B engines to crack in center exhaust seats due to heat.
Since you're in California I would find a machine shop capable of metal stitching. If not; a trip to Lock n Stitch in Turlock,CA would suffice for a reliable repair.
http://www.jandm-machine.com/metalStitching.html
J and M Machine is offline   Reply With Quote
Old 03-25-2015, 03:18 PM   #9
mshmodela
mshmodela's Avatar
J and M, impressive... given your experience, what might be an example of a crack that is beyond Lock and Stitch repair?
-Mike
Cleveland, Ohio
Old 03-25-2015, 07:01 PM   #10
1929
good question
1929 is offline   Reply With Quote
Old 03-25-2015, 08:25 PM   #11
J and M Machine
Originally Posted by 1929 View Post
good question
A Block that is cut in half.
We can repair just about anything, it's just how much do you want to pay for repairs versus finding a better block; if there are any left in your area.?
Old 03-25-2015, 08:53 PM   #12
Pete
"The only way this block would be a boat anchor is If you take it to the wrong machine shop and they weld it."
Ah yes, but you don't take welding job to a machine shop any more than you would have a carpenter do brain surgery on you.
A cast iron welding and repair shop is the place to go. Anything that is cast iron can be welded and put back to new condition or better.
Stitching is usually the best ECONOMICAL way to go for the problems described above.
Give me a couple years and you will see what can be done to a "B" block by cutting it 4 ways and welding it together to take a desmodromic head among other things.
Old 03-27-2015, 04:12 PM   #13
hardtimes
hardtimes's Avatar
Hey glenn,
Just had a thought !
IF you do not want a B block with cracks, maybe you can work with an A block with no cracks..guaranteed ! I have a striped A block that I will not be using and you have a B block that you may not be using...see what I'm saying...win/win , eh
