Can anyone advise as to the length of the standard 34 torque tube length,are they the same length for all models Sedan and Roadster?
Thanks |
All V8's are the same length within the passenger car line. Paul J.
Thanks for the reply would anyone know what that length is,
Thanks. |
For 1933-1934 Fords, regardless of what engine they had, 4 or V8, they were both built on exactly the same chassis & wheelbase. The difference in length is only in the Drive Shafts, to accommodate for the longer 4 cylinder engines.
The length of the Drive shaft in the V-8 = 60 5/32” while the Drive shaft in the 4 cylinder = 58 7/16” It follows that the Tube on the 4 cylinder was shorter by same amount. |
Thanks again but I am trying to find the torque tube length for a project I'm looking at!
Red's vintage parts has one. Maybe they will measure it for you
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes.. |
Some info here - it makes a good point about which centre you are using.
http://www.jalopyjournal.com/forum/t...e-tube.647181/ more here: http://www.jalopyjournal.com/forum/t...e-tube.335083/ Mart. |
Trevor, from Ford of Canada Service Bulletin page 125:
18-C-4505 = 53 23/32" 40-C- 4505 = 61 7/8" 46-C-4505=60 11/64" No mention of body styles Drive shaft lengths are also given. Ted |
Torque tube for a 34 ford is part No. 40-4504 length for a v8 is 61 and 13/16
