Old 02-08-2015, 09:26 PM   #1
Doctor's Ford
Doctor's Ford's Avatar
Default 33 upper door frame sill plates
I will shortly install these sill plates removed from my car near 4 years ago and need to answer a few questions. They are on primer now. What exactly are they for? Are they painted body color or do they have the same finish than door/window garnish molding? Are they visible or will be covered by the upholstery? My car is a 33 Tudor Deluxe. Thanks for any input you can provide. Manuel
Doctor's Ford is offline   Reply With Quote
Old 02-08-2015, 09:34 PM   #2
Krylon32
Default Re: 33 upper door frame sill plates
They are normally nailed and screwed to the wood over the door to conceal it. They are painted when you paint the car. They are the upper door jam tins.
Krylon32 is offline   Reply With Quote
Old 02-08-2015, 09:47 PM   #3
Doctor's Ford
Originally Posted by Krylon32 View Post
They are painted when you paint the car. They the upper door jam tins.
Thanks Krylon32. Very fast answer! If I understand correctly, then they are body color and are visible when you open the door. Right?
Old 02-08-2015, 09:52 PM   #4
DavidG
DavidG's Avatar
Right.
Old 02-08-2015, 11:29 PM   #5
rich b
rich b's Avatar
If I remember right, that also retains the rubber upper door seal.
Old 02-09-2015, 07:05 AM   #6
DavidG
DavidG's Avatar
Also correct.
