Old 12-23-2014, 02:36 PM   #1
burner31
burner31's Avatar
Default Why no "star" on my engine
Why does my engine have no star?
Replacement engine maybe? Re-stamped at factory? Worker forgot to use the star stamp? Other?
Old 12-23-2014, 02:45 PM   #2
James Rogers
James Rogers's Avatar
Default Re: Why no "star" on my engine
Typical restamp. Probably done to match a title. Not done at factory or most likely any Ford dealer.
James Rogers is offline   Reply With Quote
Old 12-23-2014, 03:58 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Here's what an original number should look like. It should start with an "A" and have a star at each end, and it was always stamped into the original rough cast, not a machined surface.
Old 12-23-2014, 04:04 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Probably a rebuilt engine that was installed at some point in time. As stated above, it was more than likely renumbered to match the title and they didn't have a star or A stamp .
Old 12-23-2014, 05:47 PM   #5
Keith True
Keith True's Avatar
Take a good look at Toms engine number,then yours.His is still in the original rough texture,yours looks smooth,from being ground off.Yours has crisp edges on the edges of the pad from the grinding,Toms has soft blurry edges from the casting molds.
Keith True is online now   Reply With Quote
