Old 11-23-2013, 11:24 PM   #1
Jim Huseby
Jim Huseby's Avatar
Default new flat head light aircraft engine
Not Model A, but fascinating. Look close. A newer 90+hp engine is in the works and, I believe, weighs 150#. www.d-motor.eu
Jim Huseby is offline   Reply With Quote
Old 11-23-2013, 11:38 PM   #2
Flathead
Flathead's Avatar
Default Re: new flat head light aircraft engine
It is kind of unusual to hear someone say "Flathead" like it is a good thing. Pretty cool.
Flathead is offline   Reply With Quote
Old 11-23-2013, 11:50 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
I can't be a good thing! Everyone knows that if a flathead engine was a good idea all engines would have them today!!
Old 11-25-2013, 12:59 PM   #4
Jim Huseby
Jim Huseby's Avatar
It's tricky to get videos of this engine running on their website, but worth while to see and hear. Try just googling "aircraft d-motor". Notice the short take-off roll and climb out angle in an LSA.
Old 11-25-2013, 01:08 PM   #5
Patrick L.
Patrick L.'s Avatar
The specs and write-up are pretty brief and some info appears to be wrong. I'd like to know the TBO.
Old 11-25-2013, 01:45 PM   #6
Jim Huseby
Jim Huseby's Avatar
On one of the videos, they mentioned a TBO of 1500 hr. and expected 2000 once it was further tested, but suggested that the jug and valve material would last indefinitely. There are videos out there, but you may have to figure out how to get them. They also said it used 2.5 GPH at a cruise of 120 mph in an LSA (two-place 1320#). The prop is direct drive and cruises at around 3000 rpm.
Old 11-25-2013, 03:19 PM   #7
CarlG
CarlG's Avatar
48 miles per gallon - not bad!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-25-2013, 04:16 PM   #8
Patrick L.
Patrick L.'s Avatar
Thanks Jim. 2.5 GPH ! I sure like that !
Old 11-25-2013, 06:58 PM   #9
dave in australia
The big downfall of this engine is that it runs on avgas. Avgas is on the way out, at least here in Australia, and it becomes more and more expensive to fill up. One of the local aero engine shops here is developing a 4cyl diesel. It is a flat 4, and 2 pistons go toward each other so there is no head, and the combustion chamber is the space between the pistons at TDC. It is a 2 stroke, so there are few moving parts.
dave in australia is offline   Reply With Quote
Old 11-26-2013, 06:33 AM   #10
Patrick L.
Patrick L.'s Avatar
Well, avgas is expensive, thats for sure. 80 disappeared from this area long ago. 100LL is about to become extinct also, replaced by a lower octane no lead. A lot of fellas do run their aero engines on mogas, but, I won't.
Old 11-26-2013, 02:18 PM   #11
Rock Hornbuckle
Rock Hornbuckle's Avatar
It seems as if Ferdinand Porsche's engine concept is alive and doing quite well.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 11-26-2013, 03:15 PM   #12
Patrick L.
Patrick L.'s Avatar
The flat engine has been around a long time. Karl Benz designed it in the 1890s and they are still going strong. I've had many over the years in both air and water cooled versions from Continental, Lycoming, Franklin, Onan, Porsche, Honda. I'm running a flat 6 in a motorcycle with a carburetor for each sparkler..
Old 11-26-2013, 07:41 PM   #13
Flathead
Flathead's Avatar
The flathead has been around a long time too, but doesn't get much respect anymore.
Old 11-27-2013, 01:43 PM   #14
Patrick L.
Patrick L.'s Avatar
I thought there was a big resurgence in flatie popularity.
