Old 03-05-2025, 08:20 PM   #1
1940_3/4-1Ton_Express
Post 1940 3/4-1 Ton express frame measurements
I have a 1940 express truck that was my grandfather's farm truck. It has a 1 ton rear axle(17" split rims) and a 3/4 ton front axle (16" solid rims). I have removed the axles for sandblasting the frame. Now that the frame is primed and installed on the frame table, I noticed the front of the frame is slightly bent. I have been searching for any dimensional information to straighten it back out. I can find the 1/2 ton frame dimensions, but not the 3/4-1 ton. Any help is appreciated. My backup plan is to take a bunch of reference points and triangulate to the opposite side.
1940_3/4-1Ton_Express is offline   Reply With Quote
Old 03-05-2025, 10:19 PM   #2
1952henry
1952henry's Avatar
Default Re: 1940 3/4-1 Ton express frame measurements
Stu or GB should be able to help.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 03-05-2025, 11:14 PM   #3
GB SISSON
GB SISSON's Avatar
I have a bare rolling frame from a '46 tonner amd a couple of complete 47 tonners here. I also have the back half of a '39 tonner that was made into a trailer for a welder. I know the axles changed width with an increase in '42 of 2 1/2". Would be easy to determine in the morning. My guess is frame rails will be the standard 34" width. I think my old '38 tonner had a transverse front leaf and I've never owned a '40 or '41. Do they have transverse front or paralell springs?? If paralell, frames may be the same and I can help you..As soon as you can get a picture of this truck posted, we'd love to see it.
Old 03-06-2025, 08:08 AM   #4
It has parallel springs. The frame is 34" outside in the rear, and 32"outside in the front. I will post some pics ASAP. I have some before teardown and in process. I "heard" it is close to the '46 frames...
Old 03-06-2025, 08:37 AM   #5
Unhappy Re: 1940 3/4-1 Ton express frame measurements
Old 03-06-2025, 09:50 AM   #6
GB SISSON
GB SISSON's Avatar
Can you give an example of the dimensions you need? The frame rails were bobbed in the rear of the roller frame for a dump bed, but intact other than that.
Old 03-06-2025, 11:48 AM   #7
petehoovie
petehoovie's Avatar
Originally Posted by 1940_3/4-1Ton_Express View Post
Old 03-06-2025, 11:53 AM   #8
GB SISSON
GB SISSON's Avatar
Yessir, that's a farm truck! Do you have the box, running boards and rear fenders or are you going with a flatbed on your build?
Old 03-06-2025, 01:05 PM   #9
We are keeping the flatbed. The story is that my grandfather had the bed made and installed by a local machine shop so he could haul seed corn in bags. We still have the "original" wooden rack(front "headache" rack) that we will use as a template to remake the sides and rear. I have some rough sawn cedar that most likely will get used for that. I will drawup some dimensions that I am looking for. The right front front spring perch was braized to the frame. It appears the the left front frame rail is bent in and down approx 1/4" inch. Probably not a big concern but I wanted to get the frame straight before getting into the suspension.
Old 03-06-2025, 01:15 PM   #10
ActionYobbo
ActionYobbo's Avatar
I have a 39 and it’s 32” at the front
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 03-06-2025, 01:26 PM   #11
truckdog62563
truckdog62563's Avatar
I have the Salesman’s Data Book for 1941, but not 1940. It has charts with dimensions. I would assume they are the same as 1940, please say if it is not, but the problem I have here is posting pictures from my phone. If GB or Owen are willing to post the pics I will email them. Stu
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
Old 03-06-2025, 02:55 PM   #12
I would like to think the 1940 and 1941 are close if not the same. I would appreciate any help. I can "trig" it out myself but it would be better to at least have some sort of starting point.
Old 03-06-2025, 03:29 PM   #13
Here are some progress pictures of the frame.
[ATTACH][ATTACH]image000004.jpg[/ATTACH][/ATTACH]
Old 03-06-2025, 03:39 PM   #14
petehoovie
petehoovie's Avatar
[ATTACH][ATTACH]Attachment 562061[/ATTACH][/ATTACH]
Old 03-06-2025, 09:17 PM   #15
GB SISSON
GB SISSON's Avatar
Problem is I just got home from a jobsite tonight and I leave at 5:30 am to go to Seattle to see the grandkids. Sorry, bad timing.
Old 03-06-2025, 09:33 PM   #16
cas3
is that a Ferrari ?
Old 03-07-2025, 03:27 AM   #17
truckdog62563
Thanks Karl. Email with three charts sent. And thanks Owen for trying to train me. I got to the point of attaching files and I lost it. Will continue to try to learn. Stu
Stu McMillan
Marmon-Herringtons
Old 03-07-2025, 12:02 PM   #18
Karl Wescott
Karl Wescott's Avatar
Copies of information from Truckdog62563...
File Type: jpg ChassisSideViewFrom1941SalesmanBook.jpg (46.2 KB, 17 views)
File Type: jpg ChassisDimensionsFrom1941SalesmanBook.jpg (95.4 KB, 18 views)
Karl Wescott is offline   Reply With Quote
Old 03-08-2025, 01:28 AM   #19
expavr
expavr's Avatar
These are the measurements from the 1940 salesman's Reference Manual.
expavr is offline   Reply With Quote
Old 03-10-2025, 02:05 PM   #20
411Ton
I have a 31 3/4 ton Frame currently at powder coating. If you let me know what dimensions you need, I'll measure it next week when its back in the garage
411Ton is offline   Reply With Quote
