Old 03-22-2022, 04:32 PM   #1
Procoat
Default 1928 Model A Frame - What is this
I have a newly acquired '28 P/U with a frame that has 4 half cylinder pieces attached. Any idea what these are? They aren't on the frame of my '30 P/U.
Procoat is offline   Reply With Quote
Old 03-22-2022, 04:44 PM   #2
SonicRaT
Default Re: 1928 Model A Frame - What is this
Those are shocks. Often leak and non-functional... sometimes, but rarely, rebuildable.
SonicRaT is offline   Reply With Quote
Old 03-22-2022, 05:20 PM   #3
mercman from oz
mercman from oz's Avatar
Ford Model A Shock Absorbers.
Old 03-22-2022, 05:38 PM   #4
BillCNC
BillCNC's Avatar
This is the time the vacuum finds your wallet. Mine came with only two and I went for the original design replacments.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 03-22-2022, 06:00 PM   #5
WTSHNN
WTSHNN's Avatar
They are hydraulic shock absorbers and came on all production Model A's. You may find the addition of them to your pickup will greatly increase the ride.
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 03-22-2022, 06:13 PM   #6
al's28/33
al's28/33's Avatar
Houdaille Hydraulic shock absorbers, every "A" had them. It is worth cleaning them good and seeing what type those are if you wanna find a guy with an early '28 looking for those parts, don't ever toss away old parts!!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 03-22-2022, 06:37 PM   #7
aermotor
Easiest and cheapest way out for shocks is modern tubular shock conversion.
aermotor is offline   Reply With Quote
Old 03-22-2022, 07:39 PM   #8
Synchro909
Synchro909's Avatar
IMO, the suppliers of these conversions should have done a little more work before taking them to market. Tele shockers are way too stiff.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-22-2022, 07:43 PM   #9
nkaminar
nkaminar's Avatar
First, disconnect the links. Looks like one is already disconnected. Try to move it up and down. Move the arm to the one that does not have one to test that one. If it moves but easily, try adding some shock oil, available from the vendors, at the square plug at the top. It if has resistance with new shock oil, congratulations, you just saved a ton of money. If not, or if frozen solid, send them in to have them rebuilt.
They are really hard to rebuilt without special tools.
If the springs are dry and stiff the car will work without shocks but the springs should be rebuilt with dry lubrication or grease and shocks added. Because they are hard to rebuild and parts were not available for a long time and because most of the shocks were worn out, lots of cars had them removed back in the day.
nkaminar is online now   Reply With Quote
Old 03-22-2022, 09:23 PM   #10
burner31
burner31's Avatar
Just had a thread about this...that's why a lot, and I mean a lot a A's had no shocks or they were disconnected.
Modern shocks work great (and much cheaper) if you are into driving and not high point showing
Keith
Shawnee OK
'31 SW 160-B
Old 03-23-2022, 07:18 AM   #11
Procoat
Thank you for the help identifying them. I am definitely going to clean/dust them off and see if they are totally shot. If they aren't totally gone, I will see about getting them rebuilt.
Old 03-23-2022, 12:28 PM   #12
lotsagas4u
Call Stipe machine shop, get on the list, might as well do it right.
lotsagas4u is offline   Reply With Quote
