Old 06-19-2021, 07:48 AM   #1
Tod
Default Miller-style cylinder head
Back in December I asked about a cylinder head that turned out to be a Miller head, and not a Winfield as was believed. Since then I went to where this head was and took some info from it and modeled it up with a combustion chamber that resembles a Winfield crow foot chamber. I test cut a sample chamber in a block of wood and calculations result in a 6.25:1 chamber.
I then CNC cut a pattern, and modeled the deck cover core and water jacket. The deck core and water jacket will be made from 3D printed sand for the first batch of orders, which looks to be some aluminum and some iron versions.
The pattern does not have any nomenclature on it yet, as I do not know what lettering will be put on it.
I believe pricing for these will be $375-400, maybe $425.
Sample pictures of the almost complete models and pattern are attached.
Tod
Tod is offline   Reply With Quote
Old 06-22-2021, 06:17 AM   #2
Tod
Default Re: Miller-style cylinder head
Here is what the water jacket and deck core look like assembled. The models are in the hands of the people that will 3D print them for prototype castings.
Tod
Old 06-22-2021, 01:30 PM   #3
Two-Gun Bob
Which style/size of spark plugs are you planning for your design?
Two-Gun Bob is offline   Reply With Quote
Old 06-22-2021, 03:54 PM   #4
Tod
The originals used pipe plug spark plugs, so that is the plan at first. 14mm will probably also be available.
Good question.
Tod
Old 06-26-2021, 11:04 AM   #5
Tod
The first sample cores assembled and ready for the foundry.
Tod
Old 07-05-2021, 04:49 AM   #6
NZFordguy
Very nice work! Looking good
NZFordguy is offline   Reply With Quote
Old 07-09-2021, 05:27 PM   #7
Tod
I assembled 2 molds today to cast 2 iron prototypes of this new head.
Tod
Old 07-14-2021, 03:52 PM   #8
Tod
First 2 iron Miller style heads shot blasted and ready to machine for testing.
Tod
Old 07-14-2021, 05:13 PM   #9
mercman from oz
mercman from oz's Avatar
Miller-style Cylinder Head - nice.
Old 08-24-2021, 05:46 PM   #10
Two-Gun Bob
Interesting project! Any progress since your last post?
Old 08-24-2021, 06:03 PM   #11
Tod
I made 2 castings. One is in a machining fixture ready to machine but I am crazy busy right now so machining is not under way yet.
Tod
Old 08-24-2021, 06:07 PM   #12
Two-Gun Bob
Okay. Do let us know when you are able to make further progress. Any thoughts on top “decoration” (script, name, etc.)?
Old 08-25-2021, 03:53 PM   #13
Tod
I'm not sure what I will do for script.
Tod
Old 08-25-2021, 11:39 PM   #14
J Franklin
J Franklin's Avatar
For script I visualized TOD written in a FORD like script, with the letters the same and the T with the Ford F flourish. It is a neat project and would be fun to own.
Old 09-08-2021, 04:19 PM   #15
Tod
Took some time to start machining on one of the first samples.
Tod
Old 10-06-2021, 08:23 AM   #16
Tod
Finally took some time to finish the top machining.
Tod
Old 10-06-2021, 08:36 PM   #17
mercman from oz
Looking good.
Old 10-13-2021, 11:03 AM   #18
QGolden
QGolden's Avatar
Fascinating project! Thank you..
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 02-23-2022, 05:20 PM   #19
Tod
Good news on the new cylinder head. Today the first sample was test run and things went well. It was run using a used gasket, so the next test is with a new gasket and then it will be dyno tested.
Tod
Old 02-27-2022, 07:40 AM   #20
Panheadguy
Hi Tod,
Is there a reason why the radius of the valve pocket area doesn't match the radius of the gasket?
Panheadguy is offline   Reply With Quote
