#21 | |
![]() Quote:
I re-read his post and I'm not sure. But I understand what you're saying and I agree with it. |
#22 | |
![]() Quote:
This is good info thanks! |
#23 |
If you want a comprehensive howto,you need to take apart all brake parts and inspect Les A ndrews first book will explain step by steo what you need to do to to have good brakes. The last thing you do is adjust them.
Good luck John
Welcome each day |
#24 |
Personally I would not follow his videos for anything. I have watched a few and there was glaring misinformation in every one. He is selling advertising. Not promoting good repairs.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup 1931 Coupe 2 Smith Motor Compressors 1951 Ford F1 High Desert Model A's |
#25 |
I think this would be a more powerful critique if you could get two guys on this board to agree about anything. Even the restoration shop owners I've talked to have poor opinions of each other's practices. Just saying "this guy says things that are wrong" doesn't carry much weight for me.
#26 | |
Would you care to elaborate? "Every one"? Not sure what set you off or triggered so much hate, but a blanket statement like that about someone trying to be of help to Model A owners deserves a bit of explanation. I don't know why there is so much hate here for my videos, but for those of you who wonder why I seldom come here or participate on FordBarn, now you know. Paul |
#27 |
Not to hijack this thread, but in the service bulletins, Ford specifically stated that the brake rods are set at the factory and are not to be adjusted when adjusting brakes. They even bold typed it.
#28 |
It's not hijacking, this fact was mentioned in the very first response.
#29 |
we need a consensus about adjusting the length of brake rods.
weren't the earliest brake rods non-adjustable? if no adjustment was ever deemed desirable, why were the brake rods threaded? |
#30 |
After all the work that I just did on my front brakes I'll have to say that adjusting them may be necessary but you should use the wedges as a first resort. I had to install pills on each side to get to the recommended 15 degrees. Then I had to adjust the rods to fit the new arm position. If I replaced the operating rods (mine were .020 under 7.25) and every other piece that could have been worn with parts that equaled exact tolerance OEM parts then the pill may not have been necessary. Impossible to tell what has been adjusted in the last 90 years. I don't think that adjusting the rods right from the start is the correct way to get the brakes dialed in.
#31 |
#32 |
You would also want to adjust them after a brake onerhaul, making sure everything else was correct. They are not to be adjusted as part of the normal service adjustment, which in the youtube video eluded to was exactly what was being done.
#33 | |
![]() Quote:
#34 | |
![]() Quote:
The video I made on brakes was done on a car with a recently replaced brake system. Since every component was replaced, mostly using reproduction parts, brake rods must be adjusted to equalize the braking force to each wheel. As mentioned in the video, once the rods are set, you do not touch them again until another component in the system is replaced. Brake pad wear is adjusted out solely with the adjusters. Let the "experts" say what they want. It's your car and your safety. |
#35 | |
![]() Quote:
#36 | |
![]() Quote:
I can think of a lot of reasons for the need to adjust the brake rods after 90 years besides worn parts. How about a slightly tweaked front axle for one. Bent frame? |
#37 |
I commented once before that with all the comments contained in the Service Bulletins on minor issues, it puzzles me that brakes are not discussed more often. Perhaps the contemporary availability of factory replacement drums solved many of our modern issues.
Anyway it would be nice if somebody had some kind of non-Company repair manual from that era addressing Ford brake jobs in detail. |
#38 |
#39 | |
![]() Quote:
I have no idea what prior owners have done with it, so I'll start fresh and set it up correctly, then probably not move them like the service bulletins say. Might want to point out, in a constructive manner, what in Paul's videos could be improved or what he may have gotten wrong that he can correct. I believe that may be more helpful. Thanks, Kevin |
