Old 03-09-2019, 06:57 PM   #1
41woodie
41woodie's Avatar
Default question for 41-48 woodie owners
I'm repairing and refinishing the wood on my 41. In doing so I'm trying to remove the metal brackets that secure the roof to the B,C, and D pillars. I've removed all of the machine and wood screws visible from inside the car from the B pillar bracket but it doesn't want to come off. I'm trying to remove it carefully as I certainly don't want to damage anything by applying too much pressure. Are there additional screws that come down through the top into the back of the bracket? These would not be visible from inside the car and would require removing the top material to access. If such fasteners are present I'll have to decide if removing and refinishing the brackets is that important right now. I really want to go on a fishing trip removing the top covering to find screws that may not exist. Thanks
41woodie is offline   Reply With Quote
Old 03-10-2019, 09:15 AM   #2
waterboychuck
waterboychuck's Avatar
Default Re: question for 41-48 woodie owners
Here's a photo of my old woodie that I no longer own under restoration. Don't bother to remove the vinyl top material as you won't see any fasteners.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 03-10-2019, 10:13 AM   #3
deuce_roadster
deuce_roadster's Avatar
Probably just old varnish holding it there. My 40 (which could be different) only has the machine screws and wood screws. There are 2 machine screws that are horizontal and the upper one goes into a T nut that is covered by a wood plug and top material on my 40, the lower one has a T nut with a stainless cap. If you have all the fasteners you can see the heads of out, then it will come off.
Old 03-10-2019, 11:19 AM   #4
woodiewagon46
Deuce is probably correct. I would just tap them lightly with a rubber mallet and they will break loose.
woodiewagon46 is offline   Reply With Quote
Old 03-10-2019, 08:49 PM   #5
41woodie
41woodie's Avatar
Thanks to all for the tips, tomorrow morning it's me and a rubber mallet.
Old 03-11-2019, 04:23 PM   #6
41woodie
41woodie's Avatar
Ok for future reference it appears that although 46-48 woodies don't have a hidden screw that secures the top B pillar bracket, 41s do have one. I was unable/unwilling to remove the soft top to access the fastener and simply cut it off from the inside for now.
I'm attaching a photo that shows the fastener that I cut and where it engages the bracket.
Old 03-11-2019, 05:52 PM   #7
woodiewagon46
So you're saying the bolt that you cut is hidden behind the roof fabric over the rain gutter?
Old 03-11-2019, 08:08 PM   #8
Mtn Wudy
Mtn Wudy's Avatar
Wondering if after you got that cut if the roof assembly just slipped right off ....??
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
Old 03-11-2019, 08:19 PM   #9
woodiejon
Where did all that rust come from on those brackets.You wanted to keep the top on it.
woodiejon is offline   Reply With Quote
Old 03-12-2019, 12:32 PM   #10
41woodie
41woodie's Avatar
Yep, it appears to be inserted from the outside and screwed into a threaded boss cast into the bracket. Not a big deal if the top covering is removed but kind of a hassle like this
Old 03-12-2019, 12:33 PM   #11
41woodie
41woodie's Avatar
Maybe I'm being too optimistic but for a piece of bare metal that has been hanging around for nearly 80 years I didn't think it was that rusty, no flaking etc.
Old 03-12-2019, 12:35 PM   #12
41woodie
41woodie's Avatar
There would be a lot more brackets and screws to deal with and it appears that the vertical pillars are mortised into the roof structure, so no nothing slipped right off other than that bracket
Old 03-12-2019, 02:41 PM   #13
woodiewagon46
Yes, they are mortised into the main roof structure.
