If I start the car in 2nd gear rolling down a hill instead od using the starter it will start imediatly, If i use the starter it harly turns and the batterycable get hot and start to smoke, I changed the starter and the battery and both battery cables and still it hardly turns over and smoke start to come from starter if i turn let it go to loong, but it still works but slovely just as the other starter that was newly overhauld and used to work perfekt weeks ago. Can it be a exchous valve that doesnt open, so it create to much compression ? its hard to hand crank when the pictons comes up .I thought aboute the bearing on axcle holding the picton rod that they might been to tight, but they are old and not touched, so probely loose instead of tight. any inputs everything have been fine until reasently it got harder and harder to start with the starter motor until almost impossible
Sounds like you have a poor connection to the starter and or the ground. Make sure all connections are clean and tight. Also that the cables are the right gauge. If that doesn't help then I would suspect the starter.
Take the starter switch apart. I bet there is a short in there. If there is, it should get very hot when you try to start it.
Jack, you are one smart cookie !!
I think Jackson means the starter switch on the top of the starter.
It would be tough for a valve to be stuck CLOSED. If so, it would run very rough or not at all.
All steel from pedal to wheel |
#8 | |
![]() Quote:
The camshaft and tappet will not allow it.
Try Ford Garage Search |
Ok thanks I changed to a starter that was tested to work very well and same thing happend turns slow and gets very hot, I tried hand crank it feels heavy to turn special when compression builds up, but not sure how hard its supose to be turning it over.
What size battery cables are you using?
Pull the spark plugs out and try to turn it over by hand. Also shine a light in those spark plug holes.
#12 | |
![]() Quote:
If a valve is tight enough to get stuck, it will stick OPEN and that will result in no compression on that cylinder.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#13 | |
![]() Quote:
I will try to remove the starter switch on top of the starter and clean it well inside for durt and bad conections as well aas look for anything abnormal withe the switch. |
#14 |
Watch the fan when you shut the engine off. It should rock back and forth as the engine stops. If it comes to an abrupt stop, the engine is binding up.
#15 |
Thanks thats a good tip, you guys knows a lot, I just got my first A Ford, if the fan comes to a quick stop could it be that the bearings in the engine is to tight ? could it be other causes as well ?
#16 |
Use a hand crank to check for hard engine cranking first. You will destroy your new starter if you try it much, pulling as hard as you describe. Awful hard on the battery and cables too.
#17 |
How easy is it to turn with a hand crank?
Make sure your starter bolts are not to long, its a very common mistake people make.. They will rub the flywheel making the engine hard to turn Try cranking it with the ignition key off, see if it helps.. this will eliminate timing / spark / ignition issue... As mentioned by Vince forget about a Valve stuck closed..that issue could also take out a fiber style timing gear, but more likely to get forced and stuck open as Synchro909 mentioned Just mentioning some more things to ponder Last edited by Mitch//pa; 01-07-2017 at 09:43 PM. |
#18 |
Show us some good pictures of your battery cables, I am betting they are not heavy enough. Gary
I am usually relatively happy------Gary ![]() |
#19 |
#20 |
Timing too advanced, and cables too small are two good things to check.
Also check that the starter switch 4 mounting screws aren't too long and shorting the field coils. The screws are 10-32 x 5/16", so don't use 3/8", which is what hardware stores would have. Last edited by Tom Wesenberg; 01-08-2017 at 09:02 AM. |
